Gimp and printing
Gimp and printing John Coppens 15 Mar 14:18
  Gimp and printing Sven Neumann 17 Mar 09:03
John Coppens
2008-03-15 14:18:39 UTC (about 17 years ago)
Gimp and printing
Though this may be a printer driver issue, I thought I'd ask first here.
Since I installed Gimp 2.4.4, the printer (HP1022) appears in the print dialog, but is marked with "printer fault!" and doesn't print. I have CUPS (1.3.6) installed, and the system does print normally from all other programs.
I have looked at newer versions of Gutenprint, but didn't find the HP1022 as supported. Do I need this newer driver? And why is the printer correctly detected, but marked as printer fault, while it works for the rest?
For now, I have been able to print to file first, then print with another program, but that's not very practical.
Thanks is advance! John
2008-03-17 09:03:35 UTC (about 17 years ago)
Gimp and printing
Since there are at least two different print plug-ins for GIMP 2.4, please tell us if you are using the "official" plug-in using the GTK+ Print user interface (which is also used in most other GTK+ and GNOME applications) or the plug-in from the Gutenprint project?
It would also be useful if you could tell us what operating system and what distribution you are running.
