gimp-vectors-stroke-get-length
gimp-vectors-stroke-get-length dorai iyer 28 Feb 01:43
  gimp-vectors-stroke-get-length David Gowers 28 Feb 04:17
  gimp-vectors-stroke-get-length saulgoode@flashingtwelve.brickfilms.com 28 Feb 04:42
   gimp-vectors-stroke-get-length dorai iyer 28 Feb 05:43
dorai iyer
2008-02-28 01:43:41 UTC (about 17 years ago)
I am trying to draw a vector ( as a single polygonal line) and then stroke it and measure its length using
gimp-vectors-stroke-get-length.
So I first used python to try to do it. Here is the script def vector_length(image, drawable):
vectors = pdb.gimp_image_get_active_vectors(image) strokes = pdb.gimp_vectors_get_strokes(vectors) len1 = pdb.gimp_vectors_stroke_get_length(vectors, stroke1, 100.0) the vectors and strokes went fine but I could not get the length
I then thought maybe I should try using tinyscheme and tried the following (let* (
(count 0)
(vector (car(gimp-image-get-active-vectors img))) (strokes (cadr(gimp-vectors-get-strokes vector))) (len (caddr(gimp-vectors-stroke-get-length vector (aref strokes count) 100.0)))
(print (list len vector))
I still get an unbound variable error. a search fo previous implementations did not show much. Has anyone used
in either scm or python successfully and can help resolve my problem. I am more familaiar with python then tinyscheme but not adept at either which is probably clearly reflected in my programming. Thanks for the help.
David Gowers
2008-02-28 04:17:54 UTC (about 17 years ago)
.. stroke1 is the unbound variable. Why would it exist? You never create it.
The following is more correct
nstrokes, strokes = pdb.gimp_vectors_get_strokes(vectors) len0 = pdb.gimp_vectors_stroke_get_length(vectors, strokes[0], 100.0)
(count 0)
2008-02-28 04:42:10 UTC (about 17 years ago)
Your Python code would seem to define 'strokes' but then access 'stroke1'. Unless 'stroke1' is defined somewhere else I should suspect this to be problematic. (I could be missing something as I never use Python.)
Your Scheme code looks fine except for the fact that 'gimp-vectors-stroke-get-length' returns a list containing just a single item, the length. Use 'car' instead of 'caddr' and your code should work.
(let* (
(count 0)
(vector (car(gimp-image-get-active-vectors img))) (strokes (cadr(gimp-vectors-get-strokes vector))) (len (car(gimp-vectors-stroke-get-length vector (aref strokes count) 100.0)))) (print (list len vector))
Quoting dorai iyer :
(count 0)
dorai iyer
2008-02-28 05:43:00 UTC (about 17 years ago)
David, Saul,
Thank you very much for the help. The corrected python code works and so does the scheme code.
(let* (
(count 0)
stroke
following
(let* (
(count 0)
implementations
did not show much. Has anyone used gimp-vectors-stroke-get-length
am
is
