Need help with help
Need help with help edward storm 12 Feb 20:26
  Need help with help Jim Sabatke 12 Feb 20:33
   Need help with help Axel Wernicke 13 Feb 00:04
edward storm
2008-02-12 20:26:08 UTC (about 17 years ago)
Need help with help
Although I am able to make progress in Peck's "Beginning GIMP" I have not been able to access or use
the Gimp help files. When I click on Help in The Gimp I get nothing. In my root directory (Leopard) in addition to Macintosh HD and Network I have Gimp, help, Gimp-2.4.3-080109-Leopard-Intel. This is what I have just after downloading Gimp-2.4.4... from "Wilbur Loves Apple".
Why does it still say "Gimp-2.4.3..." when I have downloaded "Gimp-2.4.4..."?
How can I get access to and use The Gimp's help files? I can't access the Gimp Manual either, from inside The Gimp.
I am a very raw novice at modern computing, but with considerable experience with the old-fashioned computing - Pascal, C, Lisp, Scheme and some UNIX. If you're going to try to help me please be very explicit and exact. I still don't "get it" and need all the help I can get.
Thanks
Jim Sabatke
2008-02-12 20:33:06 UTC (about 17 years ago)
Need help with help
Thanks
1. You should probably uninstall gimp 2.4.3 and then reinstall 2.4.4. 2. Gimp help is another download and install.
I'm not familiar with Mac's and how they load software, so I can't really be more specific about this.
Good luck,
Jim
Axel Wernicke
2008-02-13 00:04:28 UTC (about 17 years ago)
Need help with help
I would suggest to ask this on the wilder-loves-apple Forum. Since they did the packaging, they should know how to fix this issue.
Greetings, lexA
-- Watch out where the huskies go, don't you eat that yellow snow.
Am 12.02.2008 um 20:33 schrieb Jim Sabatke :
Thanks
Good luck,
Jim
