Question re. tool slider settings
Question re. tool slider settings Jeffery Small 03 Jan 13:47
  Question re. tool slider settings John Coppens 03 Jan 14:04
Question re. tool slider settings Jeffery Small 03 Jan 16:06
Jeffery Small
2008-01-03 13:47:55 UTC (over 17 years ago)
This is just a general question regarding the values from the various tool sliders. As an example, when I drag the Threshold slider for the Fuzzy Select tool, I get the following values: 0.0, 4.8, 9.6, 14.4, 19.2, 24.1, 28.9, etc. Similar odd sequences of numbers appear for other tool options such as Feather Edges and so on. I'm just curious why these particular numbers appear rather than some whole number divisions such as 5, 10, 15, 20, etc.
Jeffery Small
John Coppens
2008-01-03 14:04:15 UTC (over 17 years ago)
On Thu, 3 Jan 2008 12:47:55 GMT
Make the tool pane wider, and you'll get other values. The slider simply subdivides the range into the number of steps the slider can make.
John
Jeffery Small
2008-01-03 16:06:50 UTC (over 17 years ago)
John Coppens writes:
John:
Thanks for the explanation which makes perfect sense. It isn't a big problem, but I was curious as to why it operated like this.
