trick for red eye??
9 of 9 messages available
trick for red eye?? Gracia M. Littauer 25 Dec 04:23
  trick for red eye?? Owen 25 Dec 05:31
  trick for red eye?? Tim Jedlicka 25 Dec 05:38
   trick for red eye?? norman 25 Dec 13:27
    trick for red eye?? Sebastian Laube 25 Dec 14:33
     trick for red eye?? norman 25 Dec 16:27
      trick for red eye?? Gracia M. Littauer 25 Dec 20:52
       trick for red eye?? norman 25 Dec 21:46
        trick for red eye?? Owen 25 Dec 22:20
Gracia M. Littauer
2007-12-25 04:23:11 UTC (over 17 years ago)
trick for red eye??
I give up...tried everything; no banana
I did a general try, did a manually isolated try...nothing
Owen
2007-12-25 05:31:13 UTC (over 17 years ago)
trick for red eye??
If you are using 2.4, why not use the Red-Eye removal tool?
Owen
Tim Jedlicka
2007-12-25 05:38:47 UTC (over 17 years ago)
trick for red eye??
Select the "red" eye. Then Filters->Enhance->Red Eye Removal
I often use Colors->Filter Pack. Depends how bad the redeye is.
norman
2007-12-25 13:27:50 UTC (over 17 years ago)
trick for red eye??
I must be missing something, I have no Red Eye Removal tool under Filters -> Enhance, using 2.4.0-rc3.
Norman
Sebastian Laube
2007-12-25 14:33:28 UTC (over 17 years ago)
trick for red eye??
you should upgrade to the latest version... Am Tue, 25 Dec 2007 12:27:50 +0000
norman babbelte:
Norman
norman
2007-12-25 16:27:46 UTC (over 17 years ago)
trick for red eye??
Perhaps, however, I have an excellent Red Eye Removal Tool which I have used with Gimp for quite some time and which I downloaded and installed as a plug in.
Norman
Gracia M. Littauer
2007-12-25 20:52:09 UTC (over 17 years ago)
trick for red eye??
So, pray tell us!!!!! I await with bated breath....or is it the same one in latest gimp ;^)
norman
2007-12-25 21:46:33 UTC (over 17 years ago)
trick for red eye??
Whether it is the same as in the latest Gimp I do not know because I do not have the latest Gimp but it is in the list of plugins available to be downloaded and has been there quite some time.
Norman
Owen
2007-12-25 22:20:03 UTC (over 17 years ago)
trick for red eye??
You will probably find some previous correspondence on this matter when I tried to compile the plug in for 2.4 and couldn't for reasons yet to be determined
It was then that it was pointed out to me that there was already a Red Eye removal tool in 2.4 so why was I wasting my time.
So, let me suggest you either use your old Gimp with the tool, get the latest Gimp, or do it the hard way, step by step a la script steps
Owen
