gimp-gap isn't building on OSX Leopard
| gimp-gap isn't building on OSX Leopard | David Liontooth | 21 Dec 09:44 |
| gimp-gap isn't building on OSX Leopard | Sven Neumann | 21 Dec 14:45 |
Any suggestions on why gimp-gap isn't building on OSX Leopard?
# port install gimp-gap
---> Fetching gimp-gap
---> Attempting to fetch gimp-gap-2.2.2.tar.bz2 from
ftp://ftp.gimp.org/pub/gimp/plug-ins/v2.2/gap/
---> Verifying checksum(s) for gimp-gap
---> Extracting gimp-gap
---> Configuring gimp-gap
---> Building gimp-gap with target all
Error: Target org.macports.build returned: shell command " cd
"/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_graphics_gimp-gap/work/gimp-gap-2.2.2"
&& make all " returned error 2
Command output: /usr/bin/gcc-4.0 -O3 -g -Wall -Wno-switch -O2
-no-cpp-precomp -DHAVE_LRINTF -fno-common -pipe -fomit-frame-pointer
-DHAVE_AV_CONFIG_H -I.. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE
-D_GNU_SOURCE -c -o h263.o h263.c
In file included from h263.c:40:
mpeg4data.h:226: warning: pointer targets in initialization differ in
signedness
mpeg4data.h:227: warning: pointer targets in initialization differ in
signedness
mpeg4data.h:330: warning: pointer targets in initialization differ in
signedness
mpeg4data.h:331: warning: pointer targets in initialization differ in
signedness
h263.c: In function 'h263_pred_dc':
h263.c:1522: warning: pointer targets in assignment differ in signedness
h263.c: In function 'mpeg4_encode_vol_header':
h263.c:2374: warning: pointer targets in passing argument 2 of
'ff_write_quant_matrix' differ in signedness
h263.c:2375: warning: pointer targets in passing argument 2 of
h263.c: In function 'ff_mpeg4_pred_dc':
h263.c:2503: warning: pointer targets in assignment differ in signedness
/usr/bin/gcc-4.0 -O3 -g -Wall -Wno-switch -O2 -no-cpp-precomp
-DHAVE_LRINTF -fno-common -pipe -fomit-frame-pointer -DHAVE_AV_CONFIG_H
-I.. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -c -o
h261.o h261.c
msmpeg4.o msmpeg4.c
msmpeg4.c: In function 'msmpeg4_pred_dc':
msmpeg4.c:838: warning: pointer targets in assignment differ in signedness
msmpeg4.c: In function 'msmpeg4_encode_block':
msmpeg4.c:727: error: can't find a register in class 'BREG' while
reloading 'asm'
{standard input}:14980:non-relocatable subtraction expression,
"_msmpeg4v34_decode_mb" minus "L00000000003$pb"
{standard input}:14980:symbol: "_msmpeg4v34_decode_mb" can't be
undefined in a subtraction expression
{standard input}:14957:non-relocatable subtraction expression,
"_msmpeg4v12_decode_mb" minus "L00000000003$pb"
{standard input}:14957:symbol: "_msmpeg4v12_decode_mb" can't be
{standard input}:14932:non-relocatable subtraction expression,
"_wmv2_decode_mb" minus "L00000000003$pb"
{standard input}:14932:symbol: "_wmv2_decode_mb" can't be undefined in a
make[4]: *** [msmpeg4.o] Error 1
make[3]: *** [lib] Error 2
make[2]: ***
[/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_ports_graphics_gimp-gap/work/gimp-gap-2.2.2/extern_libs/ffmpeg/libavformat/libavformat.a]
Error 2
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Error: Status 1 encountered during processing.
It includes copies of ffmpeg and libmpeg3 libraries which are known to be problematic when it comes to portability. You can disable the use of these libraries when building gimp-gap. Check the output of configure --help.
