Changes in select and fill tools in 2.4, and a few new problems
Shin Diggar
2007-11-26 10:18:37 UTC (over 17 years ago)
In GIMP 2.2, If I use a selection tool (such as rectangle, elipse, freehand, etc) then once the selection is made and I release the mouse button, I can click and drag the contents of that selected area. However this behaviour has changed in 2.4 and trying to drag the selection now just moves the selection outline rather than the contents itself (previously done by holding Alt down while dragging). Is there any way to restore the old behaviour or do I now have to hold down keys to drag contents?
Also, if I select an area and then choose the fill tool, 2.4 only fills that area if I click directly on it while previous versions would let me click anywhere on the entire layer to make the fill. Can this behavior anso be restored (it still works as expected when drawing gradients in selections)? It makes matters worse when you select an area with low alpha values and the marchin ants outline either doesn't appear or only covers tiny areas. And on the subject of filling, am I right in percieving filling to be notably slower than it was in 2.2?
Another annoyance is that I no longer seem able to hold the Ctrl key down while clicking on a palet colour to set the background colour. Can this also be restored?
Additionally, I've encountered an annoyance that has appeared in 2.4. When saving an image as a JPG, the first dialogue to pop up is the large one asking for the file name and path. Then, the next one to appear is the one with the JPEG settings, which of course has an option to preview the image before saving. However, the large save dialogue is now always above the window containing the image so you can't actually see the image unless you drag the save dialogue off of the screen. The JPEG settings window still goes behind the image window, it's only the 'save' dialogue that won't go below it. Can this be fixed?
Oh, I also notice that when I use the quick eye dropper in the colour dock, the colour it sets is wrong. It's lighter than the actual colour I clicked on. The main eye dropper tool sets the colour correctly so is this a bug?
This is all in GIMP 2.4.2 on Windows XP so I'm not sure if that last issue applies to any other platforms. __________________
David Gowers
2007-11-26 12:11:43 UTC (over 17 years ago)
Ctrl-Alt-Drag to cut the selection and drag it. Alt-Shift-Drag to copy the selection and drag it.
The rectangle select and ellipse select tools are not cooperative with these, though.
Shift+Click instead, or set the 'fill entire selection' radiobutton in the tool options.
You are trying to use the new Palette color selector instead of the Palette editor. The palette editor retains that functionality; the Palette color selector never had it (I agree that it should.)
They both set the color correctly. The difference is the difference between the displayed color (after color adjustment), and the image color before adjustment.
Since the colordock eyedropper picks colors from the screen, it returns the color that is actually displayed, while the eyedropper tool/ ctrl+click with a paint tool returns the color that is stored in the image.
Jozef Legeny
2007-11-26 20:57:11 UTC (over 17 years ago)
The alt+shift+drag and ctrl-alt-drag doesn't work for me (gimp 2.4.2 on linux). I didn't find any way to change the "mouse shortcuts" but maybe I have just not searched enough, if anybody could point me to a right direction I'd be grateful.
cheers
2007-11-26 21:01:17 UTC (over 17 years ago)
They are. After you committed the selection by pressing Enter.
David Gowers
2007-11-27 00:03:19 UTC (over 17 years ago)
They are not. I specifically tried that before my first reply, and it made no difference. I had to switch to a different selection tool before they would work.
2007-11-27 00:05:53 UTC (over 17 years ago)
Works fine for me. What is different on your system?
2007-11-27 00:10:04 UTC (over 17 years ago)
Definitely works for me.
For 2.6 we hope to eliminate the need to confirm the selection before it can be floated.
David Gowers
2007-11-27 00:14:42 UTC (over 17 years ago)
Hi Sven,
Actually, now I try it again on a different picture, it works for me too. Looks like I was trying to cut out an empty part earlier.
