Gimp 2.4.1 problems with openSuse 10.3
5 of 6 messages available
Gimp 2.4.1 problems with openSuse 10.3 Stephan Hegel 02 Nov 12:25
  Gimp 2.4.1 problems with openSuse 10.3 Alex 02 Nov 12:55
  Gimp 2.4.1 problems with openSuse 10.3 Sven Neumann 04 Nov 11:21
225727.58970.qm@web51006.ma... 07 Oct 20:18
  Gimp 2.4.1 problems with openSuse 10.3 Stephan Hegel 02 Nov 13:59
   Gimp 2.4.1 problems with openSuse 10.3 Sven Neumann 04 Nov 11:24
Stephan Hegel
2007-11-02 12:25:57 UTC (over 17 years ago)
I've got the following problem with a self-compiled Gimp 2.4.1 on an openSuse 10.3 box (x86_64) when doing a simple "File->New" with no image open before:
[prompt]/home/steve: gimp *** glibc detected *** gimp: double free or corruption (out): 0x00000000037f2e40 ***
Killed
Glib2 and Gtk2 and the development packages are from the distribution itself:
[prompt]/home/steve: rpm -q glib2 glib2-2.14.1-4
[prompt]/home/steve: rpm -q gtk2
gtk2-2.12.0-5.2
Somebody out there who can reproduce this ?
Thanks & kind regards, Stephan.
Alex
2007-11-02 12:55:15 UTC (over 17 years ago)
Checked on openSuse 10.3 (x86_64, AMD) with last updates installed.
Work fine, without described error.
Configure options:
--prefix=/home/alex/programs/gimp --disable-default-binary --disable-python
image open before:
Killed
itself:
gtk2-2.12.0-5.2
Stephan Hegel
2007-11-02 13:59:40 UTC (over 17 years ago)
Alex,
All clear.
Thanks for the rpm -q output. Exactly the same like on my box.
Further analysis revealed: The problem is, that Gimp 2.4.1 tries to convert existing .gimp-2.2 resp. .gimp-2.3 directories to .gimp-2.4. This doesn't seem to be perfect. My guess (just a guess !): the templates aren't converted properly, that's why it fails when trying to open a new canvas with "File->New".
Removing all pre-existing .gimp-2.2 and .gimp-2.3 directories and letting Gimp create a brand-new .gimp-2.4 directory makes the problem disappearing.
My configure options are the defaults (incl. python), except that I've chosen another --prefix.
Kind regards, Stephan.
Alex wrote:
glib2-2.14.1-4
gtk2-2.12.0-5.2
(to complete the set:)
glibc-2.6.1-18.3
gcc-4.2-24
kernel-default-2.6.22.9-0.4
Thanks Alex,
Could you please invoke (see below)
rpm -q glib2 rpm -q gtk2
for me and send me the output ?
... and I'll try your configuration options.
Configure options:
self-compiled
Gimp 2.4.1 on an
image open before:
Killed
from
the distribution
itself:
gtk2-2.12.0-5.2
2007-11-04 11:21:52 UTC (over 17 years ago)
There have been reports about such problems and they were caused by buggy GTK+ themes.
2007-11-04 11:24:20 UTC (over 17 years ago)
Could you try to isolate the problem further? It would help a lot if you could show us a templaterc file from your ~/.gimp-2.2 directory and the result of the migration to gimp-2.4. This sounds like a problem that should be fixed for 2.4.2.
