Using shift with selection tools
4 of 5 messages available
Using shift with selection tools Dotan Cohen 16 Oct 17:17
  Using shift with selection tools Daniel Hornung 16 Oct 18:36
   Using shift with selection tools Dotan Cohen 16 Oct 20:43
4714EC88.3050403@gmail.com 07 Oct 20:18
  Using shift with selection tools Dotan Cohen 16 Oct 20:44
Dotan Cohen
2007-10-16 17:17:56 UTC (over 17 years ago)
I see that some modifier keys perform two different functions when used in conjunction with the select tools. Shift with the ellipse selector, for instance, forces circles if held while dragging. If it is held while releasing the mouse button, then it is used for adding to the selection (as opposed to replacing the selection). This dualty of shift's behaviour is troublesome. For instance, if I want to add to the current selection, but I do not want to force a perfect circle, how can I do that?
Thanks in advance.
Dotan Cohen
http://what-is-what.com http://gibberish.co.il
A: Because it messes up the order in which people normally read text. Q: Why is top-posting such a bad thing?
Daniel Hornung
2007-10-16 18:36:06 UTC (over 17 years ago)
As you said, the moment when you press the modifier key is important. For effecting the shape, have it pressed while dragging the shape, esp. in the moment you let go of the mouse button. If you simply want to change the selection mode (such as add, subtract or intersect), make sure the modifier key is pressed while you _push the mouse button down_, you can let go of the key once the mouse button is down.
I hope this helps, Daniel
Dotan Cohen
2007-10-16 20:43:49 UTC (over 17 years ago)
Thanks, Daniel. I did not realize that the deciding moment for [add||replace] was at the time that the mouse button is depressed. I will take this into account from now on.
Dotan Cohen
Dotan Cohen
2007-10-16 20:44:37 UTC (over 17 years ago)
On 16/10/2007, Michael Beckwith wrote:
Personally, I'd suggest checking out the quick mask tool as well.
I use it extensively. Thanks.
Dotan Cohen
