Problem with photo negative - solved.
        Thanks for the help and possible solutions.
I do not intend to buy _any_ proprietary software. Sorry, that dinosaur is
dead.
Unfortunately, the info is not quite what i need: i blame this on my own
missing information.
The scanner is attached to a WinNT4 box (the last Win i have bought a license
for - and the last Win i will ever install) with a bare-bone scanning
program, not able to do anything but import raw TIFF's.
The reason is, under Linux/SANE, the scanner's backend (a rather rare Microtek
Scanmaker 4) do not support transparent scans - i have discussed it with the
earlier maintainer, but he's quit, and nobody supports the scanner anymore.
I have tried to find the bug in the code, but so far, no luck.
So, i can import a raw, negative TIFF to my linux box...
I found out that i can compensate for the filter with the colour settings
(these vary with film brand), and i can 'stretch' the B/W greyscale range,
both functions using GIMP.
Now i just need to write a shell script to automate the task, as i'm per
definition rather lazy...
Thanks for your attention and help -
Kim 'The_Pirate'
