Problem with photo negative
Problem with photo negative Kim B.Christensen 16 Sep 15:44
  Problem with photo negative norman 16 Sep 16:50
  Problem with photo negative jim 17 Sep 03:46
  Problem with photo negative Johan Vromans 17 Sep 17:30
Problem with photo negative Mogens Jæger 16 Sep 16:05
Kim B.Christensen
2007-09-16 15:44:22 UTC (about 18 years ago)
Hi -
Sorry, but i have a really newbie question.
I run a GIMP 2.2.8 on a Mandriva 2006 box. And i just aquired a old flatbed scanner, able to scan 24x36 negatives - of wich i have several thousands....
When i scan a negative, it of course comes out, well, negative.
I can invert the pic with Layer/Colour/invert, but due to the colour mask in the negative, the result has a severe blue taint, and strongly reduced contrast.
Can i somehow give the image a 'preset' filter or colour mask, to counterbalance the orange filter? Or is there any other 'fix' to this problem?
Any help to a quivering n00b will be deeply appreciated...
Have fun -
Kim 'The_Pirate' Denmark
Mogens Jæger
2007-09-16 16:05:35 UTC (about 18 years ago)
Hi -
flatbed
thousands....
mask in
reduced
contrast.
this
problem?
Convert it in the scanner program - way best
Have fun -
mvh Mogens Jæger
norman
2007-09-16 16:50:18 UTC (about 18 years ago)
I expect an individual who is far more knowledgeable than me will reply with some very clever way of correcting your images but the curves tool is an excellent device for dealing with colour casts.
Norman
jim
2007-09-17 03:46:50 UTC (about 18 years ago)
Kim B.Christensen wrote:
Hi -
Have fun -
At the risk of suggesting a non FOSS solution, check out vuescan. It's on par with, if not better than the s/w bundled with most non-professional scanners. It runs on linux, you can download a trial copy to see if you like it and if it's compatible with your scanner. I scanned many hundreds of b&w/color photos/negs and slides as part of a family history project and it worked great.
A hint or two if I might. Be a tough editor. Only after you drop all but the ones you really, really want, should you go back and fix (and trust me you'll be doing lots of fixing). There are lots of tricks to neg and slide restoration. The one killer is fungus. It attacks the emulsion layers. If these are family photos, don't go cross-eyed dust spotting uncle Bob's lodge jacket or fixing somebodies smile. People are looking for faces and places.
Try to group the color slides and negs from the same time period and film stock type when you do the scans. Chances are that the dyes degraded at roughly the same rates, and you'll be able to use the same correction settings on many images which will speed things up quite a bit.
Do your best to calibrate your monitor. Go to http://www.normankoren.com/makingfineprints1A.html and read his info. If you're using a LCD style monitor, set up so that you look directly at the screen with no tilt in either axis.
Johan Vromans
2007-09-17 17:30:39 UTC (about 18 years ago)
"Kim B.Christensen" writes:
Most scanner software have a setting for negatives. SANE does.
-- Johan
