batch mode debugging
13 of 13 messages available
batch mode debugging Milos Prudek 09 Sep 11:59
batch mode debugging Milos Prudek 09 Sep 12:46
  batch mode debugging Milos Prudek 09 Sep 13:20
   batch mode debugging saulgoode@flashingtwelve.brickfilms.com 09 Sep 14:53
    batch mode debugging Milos Prudek 09 Sep 15:29
     batch mode debugging saulgoode@flashingtwelve.brickfilms.com 09 Sep 18:21
      batch mode debugging Milos Prudek 09 Sep 20:49
       batch mode debugging saulgoode@flashingtwelve.brickfilms.com 09 Sep 21:28
        batch mode debugging Sven Neumann 10 Sep 09:31
         batch mode debugging Simon Budig 10 Sep 16:52
        batch mode debugging Milos Prudek 10 Sep 12:58
         batch mode debugging Greg 10 Sep 16:30
    batch mode debugging Milos Prudek 09 Sep 15:50
Milos Prudek
2007-09-09 11:59:51 UTC (almost 18 years ago)
I need to use GIMP batch mode. I managet to reproduce the tutorial at http://www.gimp.org/tutorials/Basic_Batch/ but my own attempts fail with a very unhelpful error message "batch command: experienced an execution error."
I tried to intentionally damage the tutorial itself and I discovered that whatever syntax error I make, the error message is always the same: "batch command: experienced an execution error."
Is there a way to get at least a line number where the error occured?
Milos Prudek
2007-09-09 12:46:42 UTC (almost 18 years ago)
This is pure madness. The following line works perfectly in GIMP if used in a simple script-fu for currently loaded image.
(script-fu-fuzzy-border image drawable '(255 255 255) 120 TRUE 9 FALSE 0 FALSE TRUE)
The very same line with an added RUN-NONINTERACTIVE parameter fails if used in a batch mode script picked from http://www.gimp.org/tutorials/Basic_Batch/. I know that the error is in that line "script-fu-fuzzy-border", because if I remove the line, there are no errors. Here is the whole script, whose single purpose is to run "script-fu-fuzzy-border" over all jpg files in a directory:
(define (xxx pattern) (let* ((filelist (cadr (file-glob pattern 1)))) (while (not (null? filelist))
(let* ((filename (car filelist)) (image (car (gimp-file-load RUN-NONINTERACTIVE filename filename))) (drawable (car (gimp-image-get-active-layer image))))
(script-fu-fuzzy-border RUN-NONINTERACTIVE image drawable '(255 255 255) 120 TRUE 9 FALSE 0 FALSE TRUE)
(gimp-file-save RUN-NONINTERACTIVE image drawable filename filename) (gimp-image-delete image)) (set! filelist (cdr filelist)))))
Please help me.
Milos Prudek
2007-09-09 13:20:36 UTC (almost 18 years ago)
I simplified the above problem into the following script:
(define (fuzzy-border-single filename) (let* ((image (car (gimp-file-load RUN-NONINTERACTIVE filename filename))) (drawable (car (gimp-image-get-active-layer image)))) (script-fu-fuzzy-border RUN-NONINTERACTIVE image drawable '(255 255 255) 120 TRUE 9 FALSE 0 FALSE TRUE)
(gimp-file-save RUN-NONINTERACTIVE image drawable filename filename) (gimp-image-delete image)))
This script should be able to run with this command:
gimp -i -b '(fuzzy-border-single "foo.jpg")' '(gimp-quit 0)'
But it produces only this: batch command: experienced an execution error.
And it operates correctly if the script-fu-fuzzy-border line is replaced with (plug-in-unsharp-mask RUN-NONINTERACTIVE image drawable 1 1 1)
2007-09-09 14:53:52 UTC (almost 18 years ago)
RUN-NONINTERACTIVE is not a valid parameter for 'script-fu-fuzzy-border'.
Quoting Milos Prudek :
-- Milos Prudek
Milos Prudek
2007-09-09 15:29:15 UTC (almost 18 years ago)
On Sunday 09 of September 2007 14:53:52 saulgoode@flashingtwelve.brickfilms.com wrote:
You are right. Unfortunately when I remove RUN-NONINTERACTIVE, the script fails anyway, this time with this error message:
(jpeg:14957): LibGimp-CRITICAL **: gimp_drawable_get: assertion `width > 0 && height > 0 && bpp > 0' failed
/usr/lib/gimp/2.0/plug-ins/jpeg: fatal error: Segmentation fault
I wrote a simple Script-Fu script integrated into "right-click context menu" for an opened picture. And it works perfectly.
But the scripts I posted do not work. They should work in batch mode. Why do not they? The syntax of script-fu-fuzzy-border is exactly the same.
Here is the offending script again:
And it is called by this command:
Milos Prudek
2007-09-09 15:50:04 UTC (almost 18 years ago)
Your answer is perplexing.
A) Neither unsharp-mask.scm nor fuzzyborder.scm have "run_mode" in their parameter list.
B) script_fu_unsharp_mask AND plug_in_unsharp_mask AND script_fu_fuzzy_border do have "run_mode" in their parameter list in the Procedure Browser.
How am I supposed to discover that RUN-NONINTERACTIVE is not a valid parameter for 'script-fu-fuzzy-border' if "run_mode" is in the parameter list in the Procedure Browser, and furthermore plug_in_unsharp_mask does indeed work with RUN-NONINTERACTIVE ?
2007-09-09 18:21:09 UTC (almost 18 years ago)
It is my understanding that ALL Script-fus are run non-interactively. My guess (I am not sure of this) is that the Procedural DataBase browser lists Run Mode as a parameter because it needs to be specified if calling Script-fus from either another scripting language such as Python or from a plug-in.
Nontheless, Run Mode should not be specified when calling Script-fus from Script-fus.
The problem with your code is that, since the Fuzzy Border script is being asked to flatten the resulting image, the resulting layer does not have the same 'drawable' ID as before the flattening. If you do a second 'gimp-image-get-active layer' after flattening then you will be passing the proper 'drawable' ID to the save plug-in.
The 'Segmentation fault' is a bit scary; the JPEG plug-in should probably test whether it has been passed an invalid drawable ID.
Milos Prudek
2007-09-09 20:49:09 UTC (almost 18 years ago)
script-fu-fuzzy-border can run interactively. It is available in Right-click/Script-Fu/Decor/ menu in GIMP. It asks interactively for its parameters. Is it an interactive run?
OK. I tried to implement your idea:
(set! (drawable (car (gimp-image-get-active-layer image)))) (gimp-file-save RUN-NONINTERACTIVE image drawable filename filename) (gimp-image-delete image)))
But it outputs "batch command: experienced an execution error."
I learned the basics of Scheme yesterday. Is this some kind of scope error? Am I changing a different "drawable" variable?
2007-09-09 21:28:29 UTC (almost 18 years ago)
The dialogs for Script-fus are generated and handled by the GIMP. Unlike plug-ins and other scripting languages, there is nothing that a Script-fu script has to do to interact with the user -- the parameters are defined by the dialogs before the 'script-fu-*' function is evaluated. This is why the function is considered non-interactive.
Sort of. You have a couple of unwanted parentheses in your 'set!' statement and 'drawable' is being treated as a function. The appropriate syntax would be:
(set! drawable (car (gimp-image-get-active-layer image)))
You're doing well for only your second day with Scheme. One thing that might help you in debugging scripts is using the Script-fu console. If you open the console ("Xtns->Script-fu->Script-fu Console") and execute your command providing appropriate parameters:
(fuzzy-border-single "/home/milos/somefile.jpg")
then the error messages produced will be somewhat more useful than "experienced an execution error".
2007-09-10 09:31:05 UTC (almost 18 years ago)
On Sun, 2007-09-09 at 15:28 -0400, saulgoode@flashingtwelve.brickfilms.com wrote:
That is not quite right. The dialog is generated by the Script-Fu extension and the extension should only show the interactive dialog when the script is called in interactive mode.
The problem here is that if you call a Script-Fu script from another Script-Fu script, then you are not doing a PDB procedure call. The called script is evaluated directly by the Scheme interpreter. This may lead to a somewhat different calling convention. I haven't looked at it in detail and can't tell you exactly what this means for the run-mode.
Milos Prudek
2007-09-10 12:58:24 UTC (almost 18 years ago)
Yes! And it works. Thank you very much. This will save many hours of manual work.
Thank you for the debugging tip. It is quite discouraging when the computer tells you "your program is wrong, and I am not going to tell you what is wrong with it, not even a small hint".
Greg
2007-09-10 16:30:18 UTC (almost 18 years ago)
As a Winblows user, you get used to it. :)
_____________________________________
Simon Budig
2007-09-10 16:52:17 UTC (almost 18 years ago)
Since script-fu parses all the scripts into memory and invokes the respective functions from there it basically means, that the function gets invoked as defined, i.e. without the run mode parameter.
If you want to pass the run mode parameter you can use the function used internally by script-fu:
(gimp-proc-db-call "script-fu-sphere" RUN-INTERACTIVE 100 100 1 '(255 0 0) '(0 0 255))
I hope this helps, Simon
