color info
color info Bettina Lechner 04 Sep 16:00
  color info David Gowers 04 Sep 16:50
   color info Bettina Lechner 04 Sep 18:17
    color info Andrew 04 Sep 19:39
     color info Bettina Lechner 04 Sep 21:46
Bettina Lechner
2007-09-04 16:00:19 UTC (over 17 years ago)
color info
thank you for your answer.
but again my question. it¹s very important for me:
do you see in gimp 2.4 rc1 the entry ³color info² in the menu ³view²? where it has been under version 2.2?
tina
David Gowers
2007-09-04 16:50:27 UTC (over 17 years ago)
color info
but again my question. it's very important for me:
do you see in gimp 2.4 rc1 the entry "color info" in the menu "view"?
No. The only entry I see that is similar at all to that, is the 'padding color' entry, and I am certain that isn't what you want.
where
tina
The 'Pointer' entry under the 'dialogs' menu may be what you are looking for, as Saulgoode said.
If you just want the info window to appear by default, you can enable the corresponding (engl. 'Use Info Window') option, and Shift should then turn the info window OFF when you hold it down, it would appear at all other times.
I found your question confusing. If neither of the above is what you want, perhaps you could reword your question and I'll try to answer it better.
David
Bettina Lechner
2007-09-04 18:17:35 UTC (over 17 years ago)
color info
hi everybody,
thank you for all your answers.
Actually I am looking for the window where there where a lot of infos about a picture like:
it had 3 registers:
general: (infos about size, resolution, colors, colordepth pointer: like the pointer-dialog (I already found) and comments: exif infos(?)
where is this? thank you!
tina
but still there seems to be a problem with the info window under mac osx in gimp 2.4 rc1. it doesn't appear together with the pipette.
Am 04.09.2007 16:50 Uhr schrieb "David Gowers" unter :
where
tina
David
Andrew
2007-09-04 19:39:53 UTC (over 17 years ago)
color info
hi everybody,
it had 3 registers:
tina
Image > Image Properties ?
Andrew
Bettina Lechner
2007-09-04 21:46:49 UTC (over 17 years ago)
color info
YEAH :-)
thank you all for your help! tina
Am 04.09.2007 19:39 Uhr schrieb "Andrew" unter :
hi everybody,
it had 3 registers:
tina
Andrew _______________________________________________ Gimp-user mailing list
