color info
14 of 14 messages available
infowindow Bettina Lechner 04 Sep 11:22
  infowindow Alexander Rabtchevich 04 Sep 11:25
   infowindow Bettina Lechner 04 Sep 11:42
    infowindow Alexander Rabtchevich 04 Sep 11:49
    infowindow Axel Wernicke 04 Sep 11:54
    infowindow Alexander Rabtchevich 04 Sep 12:16
     infowindow Axel Wernicke 04 Sep 12:40
      color info, was: infowindow Bettina Lechner 04 Sep 13:12
       color info, was: infowindow Alexander Rabtchevich 04 Sep 14:12
        color info, was: infowindow Bettina Lechner 04 Sep 15:25
       color info, was: infowindow saulgoode@flashingtwelve.brickfilms.com 04 Sep 14:36
        color info Bettina Lechner 04 Sep 15:28
         color info Axel Wernicke 04 Sep 15:47
color info Andrew 04 Sep 16:27
Bettina Lechner
2007-09-04 11:22:06 UTC (over 17 years ago)
infowindow
hi all!
I am using gimp 2.4 rc1 on mac osx 10.4 (installed through macports) and I am missing the infowindow (I don't know the origin name for it in english - it's infofenster in german). in gimp 2.2. I found it in the menu view (ansicht) or it opened together with the pipette.
is this an error or is it not implemented anymore?
thank you for your informations, tina
2007-09-04 11:25:44 UTC (over 17 years ago)
infowindow
I guess you mean color info? Hold Shift when clicking with color picker.
Bettina Lechner wrote:
hi all!
Bettina Lechner
2007-09-04 11:42:59 UTC (over 17 years ago)
infowindow
I did hold down shift, but it did'nt pop up - maybe it's a x11 problem?
any ideas?
do you see the color info? which gimp version do you use? thanks tina
Am 04.09.2007 11:25 Uhr schrieb "Alexander Rabtchevich" unter :
hi all!
2007-09-04 11:49:00 UTC (over 17 years ago)
infowindow
I use GIMP for Windows - 2.3.19 or 2.4 RC1. It works on both.
any ideas?
Axel Wernicke
2007-09-04 11:54:17 UTC (over 17 years ago)
infowindow
you enabled the checkbox in the tool options of the pipette - did you?
2007/9/4, Bettina Lechner :
any ideas?
hi all!
and I
english -
newhouse - new media
Bettina Karena Lechner
neue str 16, 2565 neuhaus
austria
mobil: +43 660 46 25 0 25 tel.: +43 26 74 878 72
fax: +43 2674 878 81
mailto:lechner@newhouse.at
www.newhouse.at
Der Anfang ist die Hälfte des Ganzen. Aristoteles (384 - 322 v. Chr)
2007-09-04 12:16:39 UTC (over 17 years ago)
infowindow
Does Shift work with other tools (selection etc.)?
any ideas?
Axel Wernicke
2007-09-04 12:40:21 UTC (over 17 years ago)
infowindow
Shift is not a problem for X11 @ OS X, but Alt is ... :(
2007/9/4, Alexander Rabtchevich :
any ideas?
With respect
Bettina Lechner
2007-09-04 13:12:24 UTC (over 17 years ago)
thank you for your interest & help ­ yes shift works e.g. with the selection tool but not with the pipette, though I see that shift enables the checkbox in the tool options of the pipette (I can also check it per mouse). but no color info...
do you see the entry color info in the menu view? where it has been under version 2.2?
Am 04.09.2007 12:40 Uhr schrieb "Axel Wernicke" unter :
2007/9/4, Alexander Rabtchevich >:
any ideas?
With respect
2007-09-04 14:12:03 UTC (over 17 years ago)
I do not have 2.2 now - I use 2.3.x or 2.4 RC. Today 2.4 RC2 has been released. 2.4 has so much new nice tools, abilities and features that I recommend you upgrading. Maybe the problem is solved in 2.4.
thank you for your interest & help – yes shift works e.g. with the selection tool but not with the pipette, though I see that shift enables the checkbox in the tool options of the pipette (I can also check it per mouse). but no color info...
2007-09-04 14:36:29 UTC (over 17 years ago)
Although not presented in the same manner as the pipette's info window, perhaps you can use the Pointer ("zeiger" in German?) window available under the Dialog menu.
Bettina Lechner
2007-09-04 15:25:52 UTC (over 17 years ago)
sorry, you misunderstood me:
I already use 2.4. rc1 on mac osx and I am missing the color info. my question is, if you (under windows) find the color info in the menu "view".
thank you!
Am 04.09.2007 14:12 Uhr schrieb "Alexander Rabtchevich" unter :
Bettina Lechner
2007-09-04 15:28:47 UTC (over 17 years ago)
color info
yes here it is... thank you!
yet another question: what means the option "vereinigung prüfen" engl. perhaps "check combination, union" in this window?
Am 04.09.2007 14:36 Uhr schrieb "saulgoode@flashingtwelve.brickfilms.com" unter :
Axel Wernicke
2007-09-04 15:47:50 UTC (over 17 years ago)
color info
Hi Bettina,
you might wanna have a look to the manual to find an answer: http://docs.gimp.org/de/glossary.html#glossary-samplemerge There is also a very usagle search function in docs.gimp.org - but this doesn't mean we would not like hear from you on the list anymore :)
Happy GIMPing!
no
color info...
under
version 2.2?
austria
www.newhouse.at
Andrew
2007-09-04 16:27:04 UTC (over 17 years ago)
color info
thank you for your answer.
but again my question. it’s very important for me:
do you see in gimp 2.4 rc1 the entry “color info” in the menu “view”? where it has been under version 2.2?
tina
I think that menu entry went out after gimp 2.2. The way to get colour info now seems to be with the colour picker while holding down the shift key (at any rate under Linux)
Andrew
