Blur and Transparency
Blur and Transparency | Jürgen Hubert | 14 Aug 07:32 |
Blur and Transparency | Scott Bicknell | 14 Aug 07:43 |
Blur and Transparency | David Gowers | 14 Aug 09:11 |
Blur and Transparency | Joao S. O. Bueno Calligaris | 14 Aug 16:45 |
Blur and Transparency | Jürgen Hubert | 14 Aug 16:46 |
Blur and Transparency | Jürgen Hubert | 16 Aug 17:04 |
A minor annoyance I had to deal with is when I am attempting to use blur effects on layers with transparent areas - instead of assuming that the transparent areas have no color worth blurring at all, GIMP seems to assume that they are black for the purpose of the blurring algorithm - which can cause some rather ugly side effects.
To see what I am talking about, start with a new image with a white background. Create a new, transparent layer, and place a pure white object on it (such as a white circle). Now apply any blur function to it.
What you will see are some gray boundary areas around your white object, depending on what parameters you used for the blur effect.
Now in _my_ opinion, what ideally _should_ happen is that you see nothing at all in this case - the white of the object should be a bit more spread out with a greater graduation of the object's transparency in the boundary areas, but there shouldn't be any discolorations.
Is there some way to achieve this with GIMP?
- Jürgen Hubert
Art Tutorial Wiki: http://artwiki.wikidot.com
That's not what I see. I started with a white background layer, added a transparent layer, created a circular selection, filled it with white, deselected the area, and used Gaussian blurring with a radius of 20. It behaved as it should, spreading out the pixels and gradually blending them to the transparent areas of the layer without affecting the color. The only way it becomes visible is if I toggle the visibility of the background layer.
that they are black for the purpose of the blurring algorithm - which can cause some rather ugly side effects.To see what I am talking about, start with a new image with a white background. Create a new, transparent layer, and place a pure white object on it (such as a white circle). Now apply any blur function to it.
What I see is white; and the preview confirms that the area is only becoming
more diffuse, not discolored.
Your bug report is only meaningful if you mention what version of GIMP
you're using. Otherwise this behaviour may have been fixed since the release
you're using.
I am using the SVN version of gimp of last week.
What I see is white; and the preview confirms that the area is only becoming more diffuse, not discolored. Your bug report is only meaningful if you mention what version of GIMP you're using. Otherwise this behaviour may have been fixed since the release you're using.
Actually, I recall this in gimp 1.2 - I guess this has been fixed in GIMP 1.3 devel cycle.
js
----- Original Message -----
To:
Cc: "Jürgen Hubert"
Sent: Tuesday, August 14, 2007 7:43 AM
Subject: Re: [Gimp-user] Blur and Transparency
Strange. But admittedly I don't have the latest version of GIMP installed on this computer. I'll check again tomorrow, once I'm no longer dependant on a dial-up internet connection...
- Jürgen Hubert
Art Tutorials Wiki: http://artwiki.wikidot.com
Well, the issue is moot now - I've installed the latest version of both GIMP and GTK, and blurring works just fine, now. And as an additional bonus, the problem I had with my Intuos was solved as well...
I guess I should update more often. ;)
- Jürgen Hubert
Art Tutorials Wiki: http://artwiki.wikidot.com Free Portraits: http://juergen.the-huberts.net/1hp/main.php
