Solved: strange horizontal cursor slippage
Solved: strange horizontal cursor slippage Stephen Moss 13 Aug 12:44
Stephen Moss
2007-08-13 12:44:41 UTC (over 17 years ago)
Thanks to Akkana Peck I looked a farther than Gimp, and after much frustration......
Several weeks ago, I switched the position of my monitors, high and low screen resolution, left and right. It would seem Xorg does not like the hi-res monitor as the secondary monitor on the right. The problem did not appear immediately because there seems to be a file size factor too... only larger graphics were affected.
Should anyone have a similar problem in the future they will now be able to find the culprit.
Stephen
