GAP help, combining animations
GAP help, combining animations Patrick 10 Aug 04:20
  GAP help, combining animations Scott Bicknell 10 Aug 08:32
  GAP help, combining animations saulgoode@flashingtwelve.brickfilms.com 11 Aug 05:05
Patrick
2007-08-10 04:20:52 UTC (almost 18 years ago)
Hi Everyone
This is my first posting. I have used Gimp for a couple years and I really love it. I am just starting to use the GAP package and I need some help if you can spare it. I can do the "map to" thing and combine an image with a bunch of frames. I can split an image into frames or convert frames to an image. What I am still confused about is how to append one animation to another. I tried the "map to" option with different frame settings but the second animation just seems to get imaged over the first rather then appended after it.
Could anyone tell me how to append? Thanks for your time-Patrick
Scott Bicknell
2007-08-10 08:32:05 UTC (almost 18 years ago)
"Video/Frames Renumber..." brings up a dialog allowing you to renumber the frames by setting the first frame number and the number of digits used for each frame number.
If you give the same name to each animation's frame files, for instance "banner_" for the part before the serial number, you can renumber the frames for the animation you want to append to the end starting with the frame number after the last frame of the first animation and copy those frames to the first animation's folder.
2007-08-11 05:05:40 UTC (almost 18 years ago)
Quoting Patrick :
... What I am still confused about is how to append one animation to another. I tried the "map to" option with different frame settings but the second animation just seems to get imaged over the first rather then appended after it.
The short answer is "use the VCR Navigator" but allow me to give an example.
Let's assume you have a main animation to which you wish to append another clip. Open up the first frame from each of the animations and then perform a "Video->VCR Navigator" to raise its dialog window.
At the top of the dialog window you will see a drop-down selector which allows you to choose which of the open animations is being "navigated". Set this selector to the clip which you are appending. Next, right-click on one of the thumbnails in the list and choose the "Select All" menu item. Again right-click on a thumbnail and choose the "Copy" option.
Now go to the drop-down selector and choose your main animation. Scroll down to the very last frame, right-click on it, and select the "Paste After" option. It might take some time to perform the copy, depending upon how many frames you are adding.
Once you are aware of this method, it should be obvious that it is very similar to the standard copy-n-paste used by most programs. It should be noted, though, that every frame of your source gets duplicated into a 'video buffer' directory which will make the process slower and require more disk space than the method proposed by Scott Bicknell (it does, however, leave the original clip intact). Also, this 'video buffer' directory will retain copies of the last cut/copy operation until you manually delete them (you can clear the video buffer from the right-click menu in the VCR Navigator).
