Another problem installing gimp-2.3.19
Another problem istalling gimp-2.3.19 | julien | 30 Jul 15:11 |
Another problem istalling gimp-2.3.19 | Ulf-D. Ehlert | 30 Jul 18:48 |
Another problem istalling gimp-2.3.19 | Sven Neumann | 30 Jul 19:52 |
Another problem istalling gimp-2.3.19 | julien | 30 Jul 22:12 |
Another problem istalling gimp-2.3.19 | Tom Williams | 31 Jul 02:51 |
Another problem istalling gimp-2.3.19 | julien | 31 Jul 08:02 |
Another problem istalling gimp-2.3.19 | Michael Schumacher | 31 Jul 10:52 |
Another problem installing gimp-2.3.19 | julien | 31 Jul 15:30 |
Another problem installing gimp-2.3.19 | Patrick Shanahan | 31 Jul 15:57 |
Another problem installing gimp-2.3.19 | Ulf-D. Ehlert | 31 Jul 21:02 |
[RESOLVED] Another problem installing gimp-2.3.19 | julien | 31 Jul 22:22 |
6183605.1186101400157.JavaM... | 07 Oct 20:18 | |
Another problem installing gimp-2.3.19 | Ulf-D. Ehlert | 04 Aug 18:51 |
Under suse-10.2, I have gtk+-2.10.6. I downloaded gtk+-2.10.13, necessary for gimp-2.3.19. md5sum is right. glib-2.12.4, pango-1.14.5, atk-1.12.3, cairo-1.2.4 are installed.
./configure is OK. make gives this error : (only a part in this screenshot)
make[4]: going into directory « /home/julien/Documents/telechar/gtk+-2.10.
13/modules/printbackends/cups »
if /bin/sh ../../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I.
-I../../.
. -I../../.. -I../../../gtk -I../../../gtk -I../../../gdk
-I../../../gdk -DGTK_
PRINT_BACKEND_ENABLE_UNSUPPORTED -pthread -I/usr/include/cairo
-I/usr/include/fr
eetype2 -I/usr/include/libpng12 -I/opt/gnome/include/glib-2.0
-I/opt/gnome/lib/g
lib-2.0/include -I/opt/gnome/include/pango-1.0 -I/opt/gnome/include/atk-1.0
-DG_DISABLE_CAST_CHECKS -DG_DISABLE_DEPRECATED -g -O2 -Wall -MT
gtkprintback
endcups.lo -MD -MP -MF ".deps/gtkprintbackendcups.Tpo" \
-c -o gtkprintbackendcups.lo `test -f 'gtkprintbackendcups.c'
|| echo
'./'`gtkprintbackendcups.c; \
then mv -f ".deps/gtkprintbackendcups.Tpo"
".deps/gtkprintbackendcups.Pl
o"; \
else rm -f ".deps/gtkprintbackendcups.Tpo"; exit 1; \
fi
gcc -DHAVE_CONFIG_H -I. -I. -I../../.. -I../../.. -I../../../gtk
-I../../../gtk
-I../../../gdk -I../../../gdk -DGTK_PRINT_BACKEND_ENABLE_UNSUPPORTED
-pthread -
I/usr/include/cairo -I/usr/include/freetype2 -I/usr/include/libpng12
-I/opt/gnom
e/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include
1.0 -I/opt/gnome/include/atk-1.0 -DG_DISABLE_CAST_CHECKS
-g -O2 -Wall -MT gtkprintbackendcups.lo -MD -MP -MF
o -c gtkprintbackendcups.c -fPIC -DPIC -o .libs/gtkprintbackendcups.o
gtkprintbackendcups.c:28:23: error: cups/cups.h: No such file or directory
gtkprintbackendcups.c:29:27: error: cups/language.h: No such file or
directory
gtkprintbackendcups.c:30:23: error: cups/http.h: No such file or directory
gtkprintbackendcups.c:31:22: error: cups/ipp.h: No such file or directory
In file included from gtkprintbackendcups.c:47:
gtkprintercups.h:25:22: error: cups/ppd.h: No such file or directory
gtkprintercups.h:51: error: expected specifier-qualifier-list before
'ipp_pstate
_t'
gtkprintercups.h:67: error: expected '=', ',', ';', 'asm' or
'__attribute__' bef
ore '*' token
In file included from gtkprintbackendcups.c:49:
gtkcupsutils.h:66: error: expected specifier-qualifier-list before 'http_t'
gtkcupsutils.h:108: error: expected ')' before '*' token
gtkcupsutils.h:115: error: expected declaration specifiers or '...'
before 'ipp_
tag_t'
What is missing?
I have not these files in modules/printbackends/cups/
Greatings,
Julien
Hi Julien,
Am Montag, 30. Juli 2007 schrieb julien:
What is missing?
Package cups-devel is missing.
Try these commands when you are looking for (missing) files or packages
(this is my SuSE 9.3 output):
$ locate cups/cups.h # searching files on harddisk
/usr/include/cups/cups.h
$ ls /usr/include/cups/
cups.h http.h image.h ipp.h language.h md5.h ppd.h raster.h
$ rpm -qf /usr/include/cups/
cups-devel-1.1.23-7.6
$ pin cups.h # searching files on CD/DVD
... (output of "zgrep cups.h /var/lib/pin/ARCHIVES.gz")
(Package "findutils" should be installed for using "locate", package "pin" for using "pin".)
Bye, Ulf
What is missing?
Yes, looks a lot like it. The GTK+ configure script should however have detected this. So it would be a good idea to investigate if this should be reported as a bug against GTK+.
Thank you Ulf,
cups-devel, findutils-locate and pin now installed. But still a problem with something missing installing gtk:
-I../../../gtk -I../../../gdk -I../../../gdk
-DGTK_PRINT_BACKEND_ENABLE_UNSUPPORTED -pthread -I/usr/include/cairo
-I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include
gtkcupsutils.lo -MD -MP -MF .deps/gtkcupsutils.Tpo -c gtkcupsutils.c
-fPIC -DPIC -o .libs/gtkcupsutils.o
/bin/sh ../../../libtool --mode=link gcc -DG_DISABLE_DEPRECATED -g -O2
-Wall -o libprintbackend-cups.la -rpath
/usr/local/lib/gtk-2.0/2.10.0/printbackends -avoid-version -module
gtkprintbackendcups.lo gtkprintercups.lo gtkcupsutils.lo
-L/opt/gnome/lib -lpangocairo-1.0 -lpango-1.0 -lXfixes -latk-1.0
-lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -lcairo -lfreetype -lz
-lfontconfig -lexpat -lglitz -lm -lpng12 -lXrender -lX11 -lpthread -lXau
-lXdmcp -lm ../../../gtk/libgtk-x11-2.0.la -lcups -lssl
-lcrypto -lz -lpthread -lm -lcrypt
libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXinerama.la' seems to
be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXrandr.la' seems to be
moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXext.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXcursor.la' seems to be
moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXfixes.la' seems to be
moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libcairo.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libfreetype.la' seems to
be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libfontconfig.la' seems to
be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libglitz.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libpng12.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXrender.la' seems to be
moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libX11.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXau.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXdmcp.la' seems to be moved
gcc -shared .libs/gtkprintbackendcups.o .libs/gtkprintercups.o
.libs/gtkcupsutils.o -Wl,--rpath
-Wl,/home/julien/Documents/telechar/gtk+-2.10.13/gtk/.libs
-L/opt/gnome/lib /opt/gnome/lib/libpangocairo-1.0.so -L/usr/lib
/opt/gnome/lib/libpango-1.0.so /usr/lib/libXfixes.so
/opt/gnome/lib/libatk-1.0.so /opt/gnome/lib/libgobject-2.0.so
/opt/gnome/lib/libgmodule-2.0.so -ldl /opt/gnome/lib/libglib-2.0.so
/usr/lib/libcairo.so /usr/lib/libfreetype.so /usr/lib/libfontconfig.so
-lexpat /usr/lib/libglitz.so /usr/lib/libpng12.so /usr/lib/libXrender.so
/usr/lib/libX11.so /usr/lib/libXau.so /usr/lib/libXdmcp.so
../../../gtk/.libs/libgtk-x11-2.0.so
-L/home/julien/Documents/telechar/gtk+-2.10.13/gdk/.libs
-L/usr/lib/gcc/i586-suse-linux/4.1.2/../../../
-L/home/julien/Documents/telechar/gtk+-2.10.13/gdk-pixbuf/.libs -lcups
-lssl -lcrypto -lz -lpthread -lm -lcrypt -Wl,-soname
-Wl,libprintbackend-cups.so -o .libs/libprintbackend-cups.so
/usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-linux/bin/ld:
cannot find -lssl
collect2: ld returned 1 exit status
make[4]: *** [libprintbackend-cups.la] Erreur 1
make[4]: quitting directory «
/home/julien/Documents/telechar/gtk+-2.10.13/modules/printbackends/cups »
make[3]: *** [all-recursive] Erreur 1
make[3]: quitting directory «
/home/julien/Documents/telechar/gtk+-2.10.13/modules/printbackends »
make[2]: *** [all-recursive] Erreur 1
make[2]: quitting directory «
/home/julien/Documents/telechar/gtk+-2.10.13/modules »
make[1]: *** [all-recursive] Erreur 1
make[1]: quitting directory « /home/julien/Documents/telechar/gtk+-2.10.13 »
make: *** [all] Erreur 2
What does these "seems to be moved" mean? There is no available package for "ld" in Yast.
Greatings,
Julien
Try these commands when you are looking for (missing) files or packages (this is my SuSE 9.3 output):$ locate cups/cups.h # searching files on harddisk /usr/include/cups/cups.h
cups.h http.h image.h ipp.h language.h md5.h ppd.h raster.h $
$ pin cups.h # searching files on CD/DVD ... (output of "zgrep cups.h /var/lib/pin/ARCHIVES.gz")(Package "findutils" should be installed for using "locate", package "pin" for using "pin".)
Bye, Ulf
Looks like libssl is missing on your system:
cannot find -lssl
Peace...
Tom
julien wrote:
Thank you Ulf,
gcc -DHAVE_CONFIG_H -I. -I. -I../../.. -I../../.. -I../../../gtk -I../../../gtk -I../../../gdk -I../../../gdk -DGTK_PRINT_BACKEND_ENABLE_UNSUPPORTED -pthread -I/usr/include/cairo -I/usr/include/freetype2 -I/usr/include/libpng12 -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include -I/opt/gnome/include/pango-1.0 -I/opt/gnome/include/atk-1.0 -DG_DISABLE_CAST_CHECKS -DG_DISABLE_DEPRECATED -g -O2 -Wall -MT gtkcupsutils.lo -MD -MP -MF .deps/gtkcupsutils.Tpo -c gtkcupsutils.c -fPIC -DPIC -o .libs/gtkcupsutils.o
/bin/sh ../../../libtool --mode=link gcc -DG_DISABLE_DEPRECATED -g -O2 -Wall -o libprintbackend-cups.la -rpath /usr/local/lib/gtk-2.0/2.10.0/printbackends -avoid-version -module gtkprintbackendcups.lo gtkprintercups.lo gtkcupsutils.lo -L/opt/gnome/lib -lpangocairo-1.0 -lpango-1.0 -lXfixes -latk-1.0 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -lcairo -lfreetype -lz -lfontconfig -lexpat -lglitz -lm -lpng12 -lXrender -lX11 -lpthread -lXau -lXdmcp -lm ../../../gtk/libgtk-x11-2.0.la -lcups -lssl -lcrypto -lz -lpthread -lm -lcrypt
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXinerama.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXrandr.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXext.la' seems to be moved libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXcursor.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXfixes.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libcairo.la' seems to be moved libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libfreetype.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libfontconfig.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libglitz.la' seems to be moved libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libpng12.la' seems to be moved libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXrender.la' seems to be moved
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libX11.la' seems to be moved libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXau.la' seems to be moved libtool: link: warning:
`/usr/lib/gcc/i586-suse-linux/4.1.2/../../..//libXdmcp.la' seems to be moved gcc -shared .libs/gtkprintbackendcups.o .libs/gtkprintercups.o .libs/gtkcupsutils.o -Wl,--rpath
-Wl,/home/julien/Documents/telechar/gtk+-2.10.13/gtk/.libs -L/opt/gnome/lib /opt/gnome/lib/libpangocairo-1.0.so -L/usr/lib /opt/gnome/lib/libpango-1.0.so /usr/lib/libXfixes.so /opt/gnome/lib/libatk-1.0.so /opt/gnome/lib/libgobject-2.0.so /opt/gnome/lib/libgmodule-2.0.so -ldl /opt/gnome/lib/libglib-2.0.so /usr/lib/libcairo.so /usr/lib/libfreetype.so /usr/lib/libfontconfig.so -lexpat /usr/lib/libglitz.so /usr/lib/libpng12.so /usr/lib/libXrender.so /usr/lib/libX11.so /usr/lib/libXau.so /usr/lib/libXdmcp.so ../../../gtk/.libs/libgtk-x11-2.0.so -L/home/julien/Documents/telechar/gtk+-2.10.13/gdk/.libs -L/usr/lib/gcc/i586-suse-linux/4.1.2/../../../ -L/home/julien/Documents/telechar/gtk+-2.10.13/gdk-pixbuf/.libs -lcups -lssl -lcrypto -lz -lpthread -lm -lcrypt -Wl,-soname -Wl,libprintbackend-cups.so -o .libs/libprintbackend-cups.so /usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-linux/bin/ld: cannot find -lssl
make[4]: *** [libprintbackend-cups.la] Erreur 1 make[4]: quitting directory «
/home/julien/Documents/telechar/gtk+-2.10.13/modules/printbackends/cups » make[3]: *** [all-recursive] Erreur 1 make[3]: quitting directory «
/home/julien/Documents/telechar/gtk+-2.10.13/modules/printbackends » make[2]: *** [all-recursive] Erreur 1 make[2]: quitting directory «
/home/julien/Documents/telechar/gtk+-2.10.13/modules » make[1]: *** [all-recursive] Erreur 1 make[1]: quitting directory « /home/julien/Documents/telechar/gtk+-2.10.13 » make: *** [all] Erreur 2What does these "seems to be moved" mean? There is no available package for "ld" in Yast.
Greatings,
Julien
Bye, Ulf
It seems that libssl is installed yet:
locate libssl
/usr/lib/libssl.so.0.9.7
/usr/lib/libssl.so.0.9.8
/usr/lib/libssl3.so
/usr/X11R6/lib/Acrobat7/Reader/intellinux/lib/libssl.so
/usr/X11R6/lib/Acrobat7/Reader/intellinux/lib/libssl.so.0
/usr/X11R6/lib/Acrobat7/Reader/intellinux/lib/libssl.so.0.9.6
Greatings,
Julien
cannot find -lssl
make[4]: *** [libprintbackend-cups.la] Erreur 1Peace...
Tom
Von: julien
locate libssl
That's only the shared objects - no headers, no libs. You'll need the corresponding devel package, too.
HTH, Michael
libssl-devel not easy to find.
No libssl nor libssl-devel in Yast.
Nothing in ftp.gnome/pub/gnome sources nor in rpmfind.
In pbone I found a libssl-devel-0.9.7q-alt4.M30.1.i586.rpm but I am not
sure it suits my suse-10.2.
Nothing else with Google and Yahoo...
Can you advise me?
locate libssl
HTH, Michael
* julien [07-31-07 09:32]:
Nothing in ftp.gnome/pub/gnome sources nor in rpmfind. In pbone I found a libssl-devel-0.9.7q-alt4.M30.1.i586.rpm but I am not sure it suits my suse-10.2.
Nothing else with Google and Yahoo... Can you advise me?
09:49 wahoo:~ > webpin -d10.2 openssl-devel
Query URL:
http://benjiweber.co.uk:8080/searchservice/SearchService/Search/Simple/openSUSE_102/openssl-devel
20 results (12 packages) found for "openssl-devel" in openSUSE_102
* openssl-devel: Include Files and Libraries mandatory for Development.
installed: openssl-devel-0.9.8a-18.13 [x86_64]
- 0.9.8d [suse-update | suse-oss] {i586,ppc,x86_64} (NEWER)
@ http://anorien.warwick.ac.uk/mirrors/suse/update/10.2
@ http://download.opensuse.org/distribution/10.2/repo/oss/suse
* openssl-devel-32bit: Include Files and Libraries mandatory for Development.
(not installed)
- 0.9.8d [suse-update | suse-oss] {x86_64}
* openssl-devel-64bit: Include Files and Libraries mandatory for Development.
(not installed)
- 0.9.8d [suse-update | suse-oss] {ppc}
* openssl-ibmca-64bit: The IBMCA OpenSSL dynamic engine
(not installed)
- 1.0.0 [suse-oss] {ppc}
09:50 wahoo:~ > webpin -d10.2 compat-openssl-devel
Query URL:
http://benjiweber.co.uk:8080/searchservice/SearchService/Search/Simple/openSUSE_102/compat-openssl-devel
10 results (3 packages) found for "compat-openssl-devel" in openSUSE_102
* opt_gnome-compat-debuginfo: Debug information for package opt_gnome-compat
(not installed)
- 0.1 [BS::GNOME:/STABLE{i586} | BS::GNOME:/UNSTABLE{i586}]
@ http://software.opensuse.org/download/GNOME:/STABLE/openSUSE_10.2
@ http://software.opensuse.org/download/GNOME:/UNSTABLE/openSUSE_10.2
* gtk1-compat-debuginfo: Debug information for package gtk1-compat
(not installed)
- 0.10 [BS::GNOME:/STABLE{i586} | BS::GNOME:/UNSTABLE{i586}]
I believe that libssl is provided by compat-openssl097g-32bit-0.9.7g-13.5 on openSUSE
You will have to look at the package to see if it contains your needs as I am still w/10.1 :^)
Am Dienstag, 31. Juli 2007 schrieb julien:
With
rpm -qf /usr/lib/libssl.so.0.9.7
or
rpm --query --file /usr/lib/libssl.so.0.9.7
you will get the package owning this file: openssl.
The corresponding devel package is openssl-devel.
BTW, for SuSE-9.3 there is a YaST option "install corresponding devel packages" (top menubar -> Extras).
Bye, Ulf
Thanks to all!
gimp-2.3.19 is installed :-)
Julien
Hi Bruce,
Am Freitag, 3. August 2007 schrieb bruce:
hi I noticed ur e-mail & that You are having a problem installing GIMP.
Julian had problems installing gimp-2.3.19, but after installing the missing devel packages everything seemes to work fine.
so am I. my computer says its installed but once i make a document & i try saving it i says i cant because the program is not completly installed.
Sorry, but I don't understand your problem. You are trying to install gimp-2.3.19 using Linux, right? What is installed according to your computer? What kind of document are you trying to save, an image? What is the exact error message when you are trying to save the image?
Are You having the same problem?
No. ;-)
Bye,
Ulf
