MacPorts Gimp 2.4.0-rc1 installation
Adventures in MacPorts Land (continued) | Victor Domingos | 27 Jul 00:55 |
Adventures in MacPorts Land (continued) | Axel Wernicke | 27 Jul 07:49 |
MacPorts Gimp 2.4.0-rc1 installation | Bettina Lechner | 26 Aug 11:57 |
MacPorts Gimp 2.4.0-rc1 installation | Axel Wernicke | 26 Aug 15:52 |
Hi! I tryed to contact the fontconfig port maintainer, but had no responde yet. Meanwhile, I have uninstalled macports and tryed it all from start. I reinstalled MP and tryed to build gimp-dev again. Everything seemed to go ok, but I was not able to run it. Like a friend of mine, I get the following error message:
$/opt/local/gimp-2.3/bin/gimp-2.3
process 23395: D-Bus library appears to be incorrectly set up; failed
to read machine uuid: Failed to open "/opt/local/var/lib/dbus/machine-
id": No such file or directory
See the manual page for dbus-uuidgen to correct this issue.
D-Bus not compiled with backtrace support so unable to print a
backtrace
Abort trap
Does anyone have any idea about what this means?
Thanks in advance. I am sending an email to the port maintainer. Let's see.
Victor Domingos
Hi Victor,
Am 27.07.2007 um 00:55 schrieb Victor Domingos:
$/opt/local/gimp-2.3/bin/gimp-2.3 process 23395: D-Bus library appears to be incorrectly set up; failed to read machine uuid: Failed to open "/opt/local/var/lib/dbus/machine- id": No such file or directory
See the manual page for dbus-uuidgen to correct this issue. D-Bus not compiled with backtrace support so unable to print a backtrace
Abort trapDoes anyone have any idea about what this means?
dbus is an infrastructure component that allows applications to talk with eachother (at least that is what I understood). In GIMP dbus is used to handle the opening of images from outside (the finder in our example) and only to start GIMP once.
dbus installs a so called startup item which starts dbus with OS X. If everything goes well, you should be able to find its process:
axelwernicke$ ps -aux | grep dbus
axelwern 8538 0.3 -0,0 27452 516 p2 S+ 7:48am 0:00.01
grep dbus
messageb 167 0.0 -0,0 28544 64 ?? Ss 5:42pm
0:00.00 /sw/bin/dbus-daemon --system
axelwern 572 0.0 -0,0 28544 140 ?? Ss 5:58pm
0:00.00 /sw/bin/dbus-daemon --fork --print-pid 4 --print-address
root 957 0.0 -0,0 28544 140 ?? Ss 6:07pm
0:00.00 /sw/bin/dbus-daemon --fork --print-pid 10 --print-address
root 34 0.0 -0,0 27836 360 ?? Ss 5:42pm
0:00.02 /opt/local/bin/daemondo --label=dbus --start-cmd /opt/loc
If not, you could try to start dbus by hand (sorry, I do not know how this is done) or reboot your machine - eeek :(
Hope this helps,
lexA
Victor Domingos
Hi everyone,
I know I should ask someone else. but like Victor Domingos - I post my question also here - maybe someone of you had the same problem.
I am using macports on mac osx 10.3 and tried to install gimp 2.4.0-rc1.
but it stopped with the following error(s):
Building gtk2 with target all Error: Target org.macports.build returned: shell command " cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macport s.org_release_ports_x11_gtk2/work/gtk+-2.10.14" && make all CFLAGS+="-I/usr/X11R6/include" " returned error 2 Command output: gtkprintbackendcups.c:2409: error: request for member `num_groups' in something not a structure or union
So I contacted the gimp2-maintainer an he answered:
This problem is related not t gimp but to gtk on 10.3
You can try gtk28 but if that fails, you should ask the gtk2 maintainer
yves
unfortunatly I am not very fit to this things behind a programm... so:
how can I "try gtk28"?
what is the command? "sudo port install gtk28"?
should I than install gimp again?
or before uninstall something?
I am running gimp 2.2 (but installed with the dmg file not through macports.
might this be a problem?)
and is it
"sudo port install gimp2" or "gimp" ?
I am asking because here it is the gimp2 portfile: http://trac.macosforge.org/projects/macports/browser/trunk/dports/graphics/g imp2/Portfile
when you follow the path to gimp (without the 2) it's empty.
sorry for all these questions - but I really need gimp!
can anybody help me?
thank you very much in advance.
tina
Hi Bettina,
Hi everyone,
indeed your question is not very close releated to GIMP and I'm not sure how I can help. For me the MacPorts gimp port works very well. Am 26.08.2007 um 11:57 schrieb Bettina Lechner:
I am using macports on mac osx 10.3 and tried to install gimp 2.4.0- rc1.
eeek, I think this might already lead to the error. The OS X 10.3 is already pretty old and there are a couple of differences in the development environment between 10.3 and 10.4.
_opt_local_var_macports_sources_rsync.macport s.org_release_ports_x11_gtk2/work/gtk+-2.10.14" && make all CFLAGS+="-I/usr/X11R6/include" " returned error 2 Command output: gtkprintbackendcups.c:2409: error: request for member `num_groups' in something not a structure or unionSo I contacted the gimp2-maintainer an he answered:
yves
There is not much to say about this. He is right. You should ask the MacPort gtk2 maintainer.
unfortunatly I am not very fit to this things behind a programm... so: how can I "try gtk28"?
try a port search gtk28:
gtk28 x11/gtk28 2.8.20 Gimp
ToolKit version 2
but I'm pretty sure that GIMP 2.4 needs a more recent gtk than 2.8...
should I than install gimp again? or before uninstall something?
If there is nothing else you use MacPorts for, you could completely remove it (see http://trac.macosforge.org/projects/macports/wiki/ FAQ#HowdoIremoveoruninstallMacPorts ), reinstall it and just do a sudo port selfupdate; port sync; sudo port install gimp-app gimp
and is it
does not matter (right now), both insall 2.4.0-rc1
sorry for all these questions - but I really need gimp! can anybody help me?
tina
So in the end: mail the gtk2 maintainer - you find his address by doing a port info gtk2.
Greetings, lexA
