Failure of installing gimp-2.3.17 and gimp-2.3.18
Failure of installing gimp-2.3.17 and gimp-2.3.18 julien 20 Jul 14:55
  Failure of installing gimp-2.3.17 and gimp-2.3.18 Tim Jedlicka 20 Jul 17:32
   Failure of installing gimp-2.3.17 and gimp-2.3.18 julien 20 Jul 22:08
julien
2007-07-20 14:55:45 UTC (almost 18 years ago)
Under Suse-10.2, I have gimp-2.2 installed in /opt/gnome/bin/
I tried to install gimp-2.3.18 then, after unistalling it, gimp-2.317. In both cases,
./configure --prefix=/usr
make
#make install
ran to the end without crashing.
I have an executable gimp-2.3.x in /usr/bin/. This file is root. Is this normal?
Being root, if I launch this file, nothing happens. I console mode, I have the following message:
"/usr/bin/gimp-2.3 : symbol lookup error : /usr/bin/gimp-2.3 : undefined symbol : gimp-micro-version".
What doesthat mean? What must I do to get a valid gimp-2.3.18?
Julien
Tim Jedlicka
2007-07-20 17:32:02 UTC (almost 18 years ago)
make
#make install
Did you follow the instructions at: http://gimp.org/release-notes/gimp-2.3.html
Sounds like you kind of followed them since you added a --prefix (although I would have made it /usr/gimp-2.3 or something like that as recommended, but I would think your prefix would work also.
You then need to create the "tiny wrapper script" as described in the given readme link.
julien
2007-07-20 22:08:00 UTC (almost 18 years ago)
I was too much presumptuous; I thought I knew how to install sources. Thank you, gimp-2.3 works fine now.
Julien
Sounds like you kind of followed them since you added a --prefix (although I would have made it /usr/gimp- 2.3 or something like that as recommended, but I would think your prefix would work also.
