importing a PS brush into Gimp 2.3
importing a PS brush into Gimp 2.3 Olivier Lecarme 18 Jul 07:34
  importing a PS brush into Gimp 2.3 Sven Neumann 18 Jul 07:38
   importing a PS brush into Gimp 2.3 Olivier Lecarme 18 Jul 17:13
    importing a PS brush into Gimp 2.3 Olivier Lecarme 18 Jul 18:25
Olivier Lecarme
2007-07-18 07:34:24 UTC (almost 18 years ago)
I thought that it was possible to import a Photoshop brush into Gimp 2.3. I have one, with the .abr suffix, but I can't open it with the Open dialogue (unknown file type). How should I proceed?
By the way, one problem I have with brushes is that I'm interested in large collections of real Gimp brushes, available in some places. However, to place all of them at the same time in the brushes directory makes choosing a brush among more than thousand of them very awkward. Could it be possible to have sub-directories in the brushes directory, and to access them when needed? Presently, my only solution is to make this by hand, moving a symbolic link among the various directories I built. Pretty complicated and unnatural.
Yes, I know I should try programming this myself. But it would need so much time to learn all the stuff needed that I would not be able to do this before several months, if not years.
2007-07-18 07:38:26 UTC (almost 18 years ago)
You don't need to import it. Just place it into your brushes folder and use it. There's a good chance that this will just work.
Olivier Lecarme
2007-07-18 17:13:12 UTC (almost 18 years ago)
Unfortunately it is not the case. True, this is a very special brush, its size is 3 Mbytes! Too bad.
Olivier Lecarme
2007-07-18 18:25:06 UTC (almost 18 years ago)
Unfortunately I did not look at the proper place! The brush works perfectly well, and yet its size is 2500x2673! Thanks!
