bizarre behavior of tracing tools with GIMP 2.3
12 of 12 messages available
bizarre behavior of tracing tools with GIMP 2.3 Olivier Lecarme 14 Jul 14:35
  bizarre behavior of tracing tools with GIMP 2.3 David Gowers 14 Jul 15:08
   bizarre behavior of tracing tools with GIMP 2.3 Olivier Lecarme 14 Jul 15:21
    bizarre behavior of tracing tools with GIMP 2.3 David Gowers 14 Jul 15:45
     bizarre behavior of tracing tools with GIMP 2.3 Olivier Lecarme 14 Jul 17:53
      bizarre behavior of tracing tools with GIMP 2.3 David Gowers 15 Jul 01:48
     bizarre behavior of tracing tools with GIMP 2.3 Sven Neumann 16 Jul 17:39
      bizarre behavior of tracing tools with GIMP 2.3 Olivier Lecarme 16 Jul 19:20
       bizarre behavior of tracing tools with GIMP 2.3 Sven Neumann 17 Jul 09:10
        bizarre behavior of tracing tools with GIMP 2.3 Olivier Lecarme 17 Jul 10:29
        bizarre behavior of tracing tools with GIMP 2.3 Olivier Lecarme 17 Jul 18:29
  bizarre behavior of tracing tools with GIMP 2.3 Karine Delvare 15 Jul 18:55
Olivier Lecarme
2007-07-14 14:35:45 UTC (over 18 years ago)
I installed version 2.3.18 on two similar computers: Debian Sid and kernel 2.6.21. The problem occurs only on one of the computers, not the other. It does not occur at all with version 2.2.
With all the tracing tools that use a brush (pencil, brush, eraser, dodge and burn, etc.) but only with them, as soon as the pointer is in the image window, there appears a series of images of the current brush, light green. They don't modify the image itself, as simply redrawing it makes the images to disappear.
An example can be seen on http://pierredelune.i3s.unice.fr/bizarre.png
Since this problem makes Gimp 2.3 pretty unusable for me, I would very much like to find a solution. What other information would be useful?
David Gowers
2007-07-14 15:08:48 UTC (over 18 years ago)
I don't know. But this is a bug in your X server; it does not handle XOR drawing correctly. You may be able to configure X to work around the bug. You should probably ask this question on the appropriate list for XFree86 or X.org, whichever you are using, and provide the contents of the Device section for your video card (found in /etc/X11/XF86Config-4 or /etc/X11/Xorg.conf depending on whether you use XF86 or Xorg)
Olivier Lecarme
2007-07-14 15:21:39 UTC (over 18 years ago)
Maybe a bug in the X server, but then, why does it occur only in Gimp version 2.3, not 2.2, and in no other graphic tool ? Moreover, I have the same version of Xorg on both computers, and the problem occurs on only one. Still moreover, is not XOR drawing used for moving the pointer image anywhere on the screen?
Thus I'm asking what could be specific to Gimp 2.3.
David Gowers
2007-07-14 15:45:03 UTC (over 18 years ago)
The drawing color changed (and I think the way GDK implements the draw, which matters because GIMP increased the version of GTK they require (GTK includes GDK)) between 2.2 and 2.3
The version of Xorg is irrelevant -- that comparison only makes sense if you have the same *video card* in both systems. This bug has been reported several times, and it's directly related to X's driver for your video card.
No (XOR drawing doesn't work very well in conjunction with things like alpha blending :)
Olivier Lecarme
2007-07-14 17:53:47 UTC (over 18 years ago)
OK. The video cards are different: - on the computer where it works correctly: ATI Technologies Inc RV 370 5B60 [Radeon X300 (PCIE)]
- on the computer where it fails: ATI Technologies Inc Radeon RV100 QY [Radeon 7000/VE]
But the X driver is the same in both cases, i.e. ati. Should I try the proprietary fglrx driver?
Anyway, thanks a lot for answering me questions not really relevant to this list!
David Gowers
2007-07-15 01:48:57 UTC (over 18 years ago)
I'll add that here, I have an 'ATI Technologies Inc RV280 [Radeon 9200 PRO]' running under the normal X.org ATI driver (X.org version 7.0.0) with no XOR problems.
Yes, that would probably be wise.
No problem.
Karine Delvare
2007-07-15 18:55:23 UTC (over 18 years ago)
Bug report about that problem:
http://bugzilla.gnome.org/show_bug.cgi?id=365731
2007-07-16 17:39:36 UTC (over 18 years ago)
Yes, the color changed. No, there was no relevant change in GDK and you can easily verify that by running 2.2 and 2.3 against the same version of GTK+.
Have a look at gimprc manual page. It explains how to work around the bug in the graphics card driver.
Olivier Lecarme
2007-07-16 19:20:02 UTC (over 18 years ago)
I'm probably stupid, but I did not find anything related to the graphics card driver in the gimprc man page. Except maybe putting off the option show-brush-outline?
By the way, Michel Daenzer from the xorg-driver-ati list suggested me to try the driver from the experimental Debian depot (with no result), and to put the Option "AccelMethod" "EXA" in my xorg.conf file. The second suggestion suppresses the xor error problem, but the Wacom tablet mouse no longer traces at all, at least visibly: nothing appears in the window, but Gimp considers it to be modified. The PS/2 mouse still works normally, as well as the Wacom stylus and eraser.
Does this strange behavior suggests you something?
2007-07-17 09:10:29 UTC (over 18 years ago)
Quoting from the manual page:
(xor-color (color-rgb 0.501961 1.000000 0.501961))
Sets the color that is used for XOR drawing. This setting only exists as a workaround for buggy display drivers. If lines on the canvas are not correctly undrawn, try to set this to white. The color is specified in the form (color-rgb red green blue) with channel values as floats in the range of 0.0 to 1.0.
Olivier Lecarme
2007-07-17 10:29:22 UTC (over 18 years ago)
It escaped my scrutiny. Thanks a lot, I'll try this!
Olivier Lecarme
2007-07-17 18:29:17 UTC (over 18 years ago)
I did it (setting color-rgb to 1.0 1.0 1.0). Unfortunately, the only result is that the brush outline is now white, and still persistent.
Thus my current solution is to have the Option "AccelMethod" "EXA" in my xorg.conf file, and not use the Wacom mouse as a painting tool. This does not prevent me to use Gimp 2.3, fortunately.
