Gimp shutting down after starting on OS X
Gimp shutting down after starting on OS X Mike Hatcher 14 Jun 18:58
  Gimp shutting down after starting on OS X Axel Wernicke 14 Jun 20:30
Mike Hatcher
2007-06-14 18:58:55 UTC (almost 18 years ago)
I'm a beginner with GIMP and after trying several times installing and uninstalling Gimp 2.2.10 on my OS X 10.4 Macbook laptop it will never load the icon will appear then automatically close leaving the X11 application running. I performed the same installation procedure on a G4 desktop at work and it worked flawlessly. I have observed in other various forums that this problem has plagued other Mac laptop users. I was wondering if you could shed any light on this incident.
Thank you
Axel Wernicke
2007-06-14 20:30:10 UTC (almost 18 years ago)
Hi Mike,
so I guess you installed the GIMP.app prebuild package? There is no general problem with GIMP on OS X. Where did you install GIMP.app? Any unusual characters in the path?
Greetings, lexA
Am 14.06.2007 um 18:58 schrieb Mike Hatcher:
Thank you
