How to tone down sun spots
How to tone down sun spots DJ 01 Jun 01:46
  How to tone down sun spots jim feldman 01 Jun 18:38
DJ
2007-06-01 01:46:06 UTC (almost 18 years ago)
Hi gimp-user,
I'm not sure what they are called in photographic terminology, but I have a picture of a long winding road with sunspots. The sun shines through the trees and is so bright that the eye immediately goes to those spots. They are pretty big at the beginning of the road. I need to brighten the picture, but how do I tone down those spots on a gravel road. They appear almost white.
I've played around with a couple of processes, but nothing looks realistic or addresses the problem. Any suggestions?
Thank you.
jim feldman
2007-06-01 18:38:28 UTC (almost 18 years ago)
DJ wrote:
Hi gimp-user,
Thank you.
Do you have an example online somewhere? Do you have a raw file for the image? The reason I ask, is that if the "spots" are blown out (that is they are pure white with no detail) there may not be much to do short of actually retouching them out of the picture. The raw image might still have detail that a camera created jpg lost. If so, you could create overlays to capture the high and low details (I can dig up some links on how). You could create a mask to tone them down, but then you end up with gray dots and my personal opinion is that looks worse.
Unless this is a "special" picture, it may not be worth your time. Chalk it up as a learning experience on how to better visualize your final images as you look through the viewfinder.
jim
