Script-fu help
Quoting ASJF :
Hi everybody !
I have made a script to resize picture... but it doesn't work anymore, I
have change something but I don't remember what...
Can someone help me?
I suspect that you are using the development version (2.3) of the GIMP
and your difficulty is caused by the fact that Script-fu has become
more demanding that you follow proper Scheme programming guidelines
than it used to be.
In previous versions of Script-fu, you were allowed to 'set!' an
undeclared variable and Script-fu would happily go ahead and define it
for you. This is no longer acceptable -- you must declare your
variables (with either 'define' or 'let*') before you use them.
In particular, you have two variables -- 'f1-height' and 'f1-width' --
which need to be included in your 'let*' block. Once you do this, I
think you will find your script to be functional.
