Splitting images for web
7 of 10 messages available
Splitting images for web Victor Domingos 24 May 09:24
  Splitting images for web Renan Birck 24 May 23:12
  Splitting images for web Sven Neumann 25 May 08:43
b35b68a00705240420j1c27d847... 07 Oct 20:18
  Splitting images for web Victor Domingos 24 May 20:17
28914.201.2.112.6.118000727... 07 Oct 20:18
843795.7622.qm@web52201.mai... 07 Oct 20:18
  Splitting images for web Victor Domingos 24 May 20:18
   Splitting images for web Sven Neumann 25 May 09:11
Victor Domingos
2007-05-24 09:24:00 UTC (almost 18 years ago)
Hi!
There used to be, in some GIMP versions, a filter, or a script-fu that allowed us to split an image for a website, similar to what Fireworks and ImageReady do. I cannot find it anymore, at least in Mac and Windows versions. Am I missing anything, or it only runs on Linux?
Thanks in advance!
Victor Domingos http://lojamac.com/blog
Victor Domingos
2007-05-24 20:17:36 UTC (almost 18 years ago)
Em 2007/05/24, às 12:20, Maurits Rijk escreveu:
The SliceTool in GIMP# (http://sourceforge.net/projects/gimp- sharp/) is probably what you want.
Sadly, I guess this tool is not available for Mac users... :( Ihave only found there a windows version. Do you know if it is possible to compile it to run under MacOS X?
Thanks, Victor Domingos
Victor Domingos
2007-05-24 20:17:51 UTC (almost 18 years ago)
Em 2007/05/24, às 12:47, João S. O. Bueno Calligaris escreveu:
Hi VIctor -
This feature is (and has been) available either in gimp Perl extensions as
"perl-o-tine", or gimp python extensions, as filters->web->py-slice.
If you are not on windows, just install gimp-pyrhon to get it working.
if you can´t install any of these, there is image->transform-
guillotine,
but that will require you to manually save your image slices and write the
needed HTML.
js
I have python intalled, I guess it came with MacOS X. Where can I get py-slice? Or where can I get gimp python extensions compiled for MacOS X?
Thanks,
Victor Domingos
Victor Domingos
2007-05-24 20:18:59 UTC (almost 18 years ago)
Em 2007/05/24, às 13:12, Elwin Estle escreveu:
No, It just cuts up images. There is perlotine, which I think will do that, but it
isn't available for windows, I don'think.
Here is the link. http://registry.gimp.org/plugin?id=427
...here's another one, Webotine. Direct link to the .scm file. The comments say it
generates HTML.
http://www.ve3syb.ca/software/gimp/2.2/webotine.scm
I copied the above script into my scripts folder (I am at work, running the portable
version of Gimp) and it seemed to run, tho I didn't slice anyting up or generate the
code.
I tried web-o-tine, but i get an error (see attached image file, please). I have no idea about what happened. maybe it isn't compatible with this GIMP version, or maybe there is something missing in my system (I am running MacOS X Tiger).
I don't run Windows, I use a Mac (PPC, not Intel, by the way). Is perlotine available for MacOS X, anywhere?
Renan Birck
2007-05-24 23:12:39 UTC (almost 18 years ago)
Em Qui, 2007-05-24 às 08:24 +0100, Victor Domingos escreveu:
Something like Web-O-Tine?
http://registry.gimp.org/plugin?id=2821
I have never used it, though.
2007-05-25 08:43:04 UTC (almost 18 years ago)
I guess you are looking for py-slice. Most probably your installation comes without the GIMP Python binding and is thus missing this plug-in.
2007-05-25 09:11:59 UTC (almost 18 years ago)
Next time, please copy and paste the error messages instead of attaching a screenshot. The error message seems pretty obvious to me though. The script tries to save in ~/Desktop and it appears that this folder doesn't exist on your system.
