hi, merge two jpg together, the 2nd one does not display
hi, merge two jpg together, the 2nd one does not display Suin Edit 08 May 07:59
  hi, merge two jpg together, the 2nd one does not display Scott Bicknell 08 May 08:27
Suin Edit
2007-05-08 07:59:27 UTC (almost 18 years ago)
Dear All
I just installed the GIMP on my windows box. My task is simple, merging two jpg files together.
When I increase the canvas size and copy and paste the second jpg into the first one, there is only a dashed outline of the second picture. I have no idea what's wrong.
Could anyone help me?
Thanks.
Scott D.
_____________________________________
Scott Bicknell
2007-05-08 08:27:37 UTC (almost 18 years ago)
When you paste the second image, you have to do one of two things as your next action before anything else. You must either click the New Layer button or the Anchor button in the layers dialog. The first will create a new layer from the pasted image. The second will merge the pasted image into the top-most visible layer of the target image. Once you do one of those two things your pasted image will show.
But increasing the canvas size may not be enough if you have an existing layer you want to paste the image into. The canvas is one thing. Layers are another. And they are not necessarily the same size.
Increasing the canvas size just gives your layers, whatever size they happen to be, more room to be arranged in.
If you want to paste a large image into a small layer, only part of the pasted image will show. If you make it a separate layer, you will avoid that trouble, as long as your canvas is large enough to accommodate the size of the pasted image.
