python-fu and menus.
python-fu and menus. John R. Culleton 16 Apr 18:14
  python-fu and menus. Renan Birck Pinheiro 16 Apr 22:28
   python-fu and menus. John R. Culleton 16 Apr 22:43
    python-fu and menus. Renan Birck Pinheiro 16 Apr 23:01
     python-fu and menus. Andrew 16 Apr 23:27
    python-fu and menus. Michael Schumacher 16 Apr 23:32
John R. Culleton
2007-04-16 18:14:26 UTC (about 18 years ago)
There are several python-fu scripts installed but they don't show up under the xtn menu or anyplace else I can find when running Gimp. Only the sphere.py script shows up. Gimp 2-3-13 on Slackware 11.
2007-04-16 22:28:59 UTC (about 18 years ago)
Em Seg, 2007-04-16 às 12:14 -0400, John R. Culleton escreveu:
Did you put them in ~/.gimp-2.3/plugins and chmod +x them?
John R. Culleton
2007-04-16 22:43:12 UTC (about 18 years ago)
No. I had expected them to be picked up just as the script-fu plug-ins were. I did what you suggested and restarted Gimp. They were picked up as new plugins during the startup display but I still can't find them on a menu. The only entry on the python submenu is sphere.py, which was there when I started.
2007-04-16 23:01:16 UTC (about 18 years ago)
Em Seg, 2007-04-16 às 16:43 -0400, John R. Culleton escreveu:
They were picked
Then I don't know. Strange issue.
Since sphere.py shows up, it doesn't seem to be an issue with Python-fu interpreter.
Do you get any strange output when running GIMP from a terminal?
Andrew
2007-04-16 23:27:31 UTC (about 18 years ago)
They were picked
I have the same problem, also Slackware 11, Gimp 2.3.13.
Andrew
2007-04-16 23:32:58 UTC (about 18 years ago)
They do not necessarily show up there - scripts and plug-ins can register themselves in any menu they want (and with 2.3, an increasing number of context menus as well)
Thus the register calls is what you have to look for in the scripts.
HTH, Michael
