Add a bit
Add a bit Andrew 12 Apr 11:28
  Add a bit Andrew 12 Apr 11:45
  Add a bit Paul Surgeon 12 Apr 12:47
   Add a bit Matthias Julius 12 Apr 14:41
    Add a bit Andrew 12 Apr 21:13
  Add a bit Michael Satterwhite 12 Apr 15:30
Andrew
2007-04-12 11:28:36 UTC (over 18 years ago)
Add a bit
Hi. I have just started using gimp, and mosly I am getting on ok with help files and google. However, one thing is driving me nuts. If I want to add a bit to a picture, I make it bigger, using Image Canvas Size, and then paste in the bit I want to add. It shows up when I paste it, in the middle, but when I drag it to the place I want to use it, in the new bit, it dissapears!? Is this a bug? Am I doing something wrong? Please enlighten me!
TIA
Andrew
Andrew
2007-04-12 11:45:39 UTC (over 18 years ago)
Add a bit
If I understand you correctly, I think what you are doing wrong is trying to paste directly to the canvas, which I think can't be done. Try adding a new layer first and pasting in to that,
HTH
Andrew
Paul Surgeon
2007-04-12 12:47:54 UTC (over 18 years ago)
Add a bit
TIA
Andrew
If your image is only a single layer then after changing the canvas size, flatten the image before pasting in a new selection. I'm not sure of this but based on the behaviour it seems as if the canvas resize operation adds an alpha channel and sets the new border area around the old image to transparent.
Flattening the image will remove the alpha channel.
Paul
Matthias Julius
2007-04-12 14:41:43 UTC (over 18 years ago)
Add a bit
Paul Surgeon writes:
The whole issue here is that increasing the canvas size doesn't make the background layer bigger. There are a couple of ways to work around that:
- after increasing the canvas size right-click on the background layer and choose "Layer to Image Size"
- after pasting the selection it will show up as "Floating Selection" in the Layers window. Right-click on it and select "New Layer". This makes the inserted bit a new layer that you can move around freely on the canvas. It has the advantage that you can always manipulate independently from the rest of the image.
Matthias
Michael Satterwhite
2007-04-12 15:30:43 UTC (over 18 years ago)
Add a bit
I made the same mistake early on.
Just because the canvas is larger doesn't mean the available layer is the same size. After you expand the canvas, either add a layer, or expand the background layer to the size of the canvas (available from the layers menu). Then you can put the new part of the image where you want.
Andrew
2007-04-12 21:13:46 UTC (over 18 years ago)
Add a bit
Matthias
