is it possible to create a fade transition .gif iwth GIMP
is it possible to create a fade transition .gif iwth GIMP Bob Meetin 06 Apr 19:21
  is it possible to create a fade transition .gif iwth GIMP Axel Wernicke 06 Apr 23:17
Bob Meetin
2007-04-06 19:21:55 UTC (about 18 years ago)
Subject says it all, mostly. I'd like to know if it is possible to create a fade-in, fade-out transitional effect with a single .gif image using GIMP? Preferaby where the image one fade out intersects with the image two fade in? -Bob
Axel Wernicke
2007-04-06 23:17:22 UTC (about 18 years ago)
Am 06.04.2007 um 19:21 schrieb Bob Meetin:
You can save layered images to gif as animated gif. By doing so, each layer is used as one frame of the animation. You might wand to have a look to the manual at page http:// docs.gimp.org/en/gimp-dialogs-structure.html and http://docs.gimp.org/ en/gimp-images-out.html#id2557519
greetings, lexA
