question
question Steven Howe 30 Mar 21:10
  question Manish Singh 30 Mar 21:16
   question Steven Howe 30 Mar 21:40
    question Joao S. O. Bueno Calligaris 30 Mar 22:21
Steven Howe
2007-03-30 21:10:15 UTC (about 18 years ago)
question
pdb.gimp_get_image_list()
returns a list of ids, which are 32bit integers, not a list of images. I know this as I tried in a
pygimp console (with two images open): ------------------------
( listLen, theList) = pdb.gimp_image_list() print listLen
print theList
(3,2)
for item in theList:
print pdb.gimp_image_get_filename( item )
Traceback (most recent call last):
File "/usr/lib/gimp/2.0/plug-ins/gtkcons.py", line 267, in run exec cmd in self.namespace
File "", line 2, in ?
TypeError: wrong parameter type
-------------------- The blurb calls the return value (number of images, list of image_ids). So, what is the method to resolve image_id to an 'image' ?
Thanks, Steven Howe
Manish Singh
2007-03-30 21:16:26 UTC (about 18 years ago)
question
Use gimp.image_list() instead, which returns a list of Image objects.
-Yosh
Steven Howe
2007-03-30 21:40:56 UTC (about 18 years ago)
question
Thanks Manish;
next question, where is the list of 'gimp' calls? the pdb didn't report this item. Under linux, In an ordinary terminal when I run python and import gimp, and type (help gimp) the process terminates with an error messgae. Is there a list of 'gimp' calls some where?
Thanks Steven Howe
-Yosh
2007-03-30 22:21:29 UTC (about 18 years ago)
question
On Friday 30 March 2007 16:40, Steven Howe wrote:
Thanks Manish;
Thanks Steven Howe
Hi Steven
you have to open the phython consoel from withn the GIMP to be able to explore the gimp module.
Unfortunatelly tehre is no docuemtnation of the methods and properties available under gimp., or image objects, drawable objects other than python-fu source code, or exeperimenting with "dir" from within a python console started withn the GIMP.
js ->
-Yosh
