Synchronize tools among input devices
8 of 8 messages available
Synchronize tools among input devices Dave M G 26 Mar 10:26
  Synchronize tools among input devices Dave M G 01 Apr 03:46
   Synchronize tools among input devices David Gowers 01 Apr 08:16
    Synchronize tools among input devices Dave M G 01 Apr 16:51
   Synchronize tools among input devices GSR - FR 01 Apr 16:57
    Synchronize tools among input devices Joao S. O. Bueno Calligaris 02 Apr 13:42
     Synchronize tools among input devices Dave M G 02 Apr 14:50
      Synchronize tools among input devices GSR - FR 02 Apr 17:37
Dave M G
2007-03-26 10:26:27 UTC (about 18 years ago)
GIMP,
The default behavior for input devices is for them to have separate control over their tools.
So, for example, if I have selected to use the airbrush tool with my pen (stylus) device, and then pick up my mouse (cursor), it will switch away from the airbrush and go to whatever my mouse was last using. The erasor tip of my Wacom pen uses yet another tool. The foreground and background colours change in accordance with the input devices as well.
Is it possible to configure GIMP so that all devices are using the same tools and colours? So that if I select the airbrush with my pen, and then pick up my mouse, the mouse will stay in airbrush mode?
Dave M G
2007-04-01 03:46:37 UTC (about 18 years ago)
GIMP Users,
Is the request I describe below impossible in GIMP?
Thanks for any advice.
David Gowers
2007-04-01 08:16:02 UTC (about 18 years ago)
On 4/1/07, Dave M G wrote:
GIMP Users,
Dave,
As far as I know it is indeed impossible.
Dave M G
2007-04-01 16:51:54 UTC (about 18 years ago)
David,
Thank you for responding.
That's quite a disappointment.
Oh well... guess I'll have to find another way deal with this.
Does anyone happen to know if it's possible to toggle "Window Mode" and "Screen Mode" for a device with a keyboard shortcut?
GSR - FR
2007-04-01 16:57:14 UTC (about 18 years ago)
martin@autotelic.com (2007-04-01 at 1046.37 +0900):
I do not think so, but you can drag and drop in devices dock to copy settings. Yeah, I know, lots of manual work, every time.
GSR
2007-04-02 13:42:15 UTC (about 18 years ago)
GSR
/me sues GSR for spreading FUD. :-)
martin: most setigns can be shared - just go to ->File->Preferences, and check the Tool Options tab.
js ->
Dave M G
2007-04-02 14:50:31 UTC (about 18 years ago)
Joao,
I've done this and under "Paint Options Shared Between Tools" I have "Brush", "Pattern", and "Gradient" selected.
But regardless, when I switch from cursor to pen devices, the settings don't carry over.
GSR - FR
2007-04-02 17:37:09 UTC (about 18 years ago)
martin@autotelic.com (2007-04-02 at 2150.31 +0900):
Joao,
Read again and try it yourself if needed. ;]
The dock has more items than the preferences (Tool, FG and BG), and the shared options are among tools, not among devices. Something like "Share tools among devices" in "Input Devices" would be needed first to solve the issue.
GSR
