Vertical gradients
Vertical gradients Andrew Scott 19 Mar 22:59
  Vertical gradients Joao S. O. Bueno Calligaris 19 Mar 23:33
  Vertical gradients Stephan Hegel 20 Mar 01:47
Andrew Scott
2007-03-19 22:59:35 UTC (over 18 years ago)
Vertical gradients
I am new to the list and would consider myself a rank beginner. I am using GIMP 2.2.11 on Linux, Ubuntu Dapper 6.06.
The photo I am procesing has rather bright sky / highlights towards the top, and I would like to de-emphasise them.
Question: how do I apply a grey or neutral filter with a vertical gradient to the photograph? And how can this gradient be adjusted to suit? I checked the web site and documentation, but my time-limited search did not come up with anything.
Many thanks in advance, Andrew
___________________________________________________________ New Yahoo! Mail is the ultimate force in competitive emailing. Find out more at the Yahoo! Mail Championships. Plus: play games and win prizes. http://uk.rd.yahoo.com/evt=44106/*http://mail.yahoo.net/uk
2007-03-19 23:33:42 UTC (over 18 years ago)
Vertical gradients
Hi Andrew -
pick the gradient tool (blend tool), assure your self it is blending in linear mode, from black to white (i.e. the default parameters - witht he default gradient (fg to bg) and default colors (B & W) ) - test to make sure, you can always undo it.
Then, turn on the "quick mask" mode - jsut click on teh small sqaure to the left of the horziontal scroll bar on the window. The image iwll be covered by a translucent red tint ,w hich is an indication of the (un)selected areas. While on quick-mask mode, all paint operations work on the selection, instead of the image. That means you can amek aselection that will let changes to the image happen with varying strenght, according to the gray-level used on the quick mask.
So, witht he quick mask on, make your gradient, turn off the quick mask. You should see an horizontal selection mark close to the middle of the image - this mark is always where teh selection has half strenght. (turn it off in the view menu if you prefer). Apply your filter now.
If the result is not good, undo a few steps, and apply layer->colors->curves on the quickmask, after you apply your gradient, to tune the result.
js ->
____________
Stephan Hegel
2007-03-20 01:47:39 UTC (over 18 years ago)
Vertical gradients
Hi Andrew,
Might be this is helpful:
http://www.gimpguru.org/Tutorials/NDFilter
Regards, Stephan.
