gimp and subversion
| gimp and subversion | Bernhard D Rohrer | 05 Mar 02:16 |
| gimp and subversion | Matthias Julius | 05 Mar 04:45 |
| gimp and subversion | Shlomi Fish | 05 Mar 18:27 |
| gimp and subversion | Bernhard D Rohrer | 16 Mar 04:33 |
| gimp and subversion | Michael Schumacher | 05 Mar 10:59 |
| gimp and subversion | Bruno Postle | 06 Mar 22:37 |
gimp and subversion
Hi all
has anybody ever thought about using Gimp with Subversion? I'd love a module that allows me to make sense of my edited versions of an image. I couldn't find a plugin though :(
cheers
Bernhard
gimp and subversion
Bernhard D Rohrer writes:
Subversion or most other revision control systems are optimized for text data. But, this doesn't mean it would work with images. It just can not store differences between image versions and therefore it has to store the whole file even if you only changed one pixel.
I don't know of any RCS that would be better suited for binary data or even be specialized for images.
But, why do you need a Gimp plugin for that? There are plenty of graphical frontends for Subversion in case you don't like the command line.
Matthias
gimp and subversion
Von: Bernhard D Rohrer
There has been a - rather abstract - suggestion of image versioning, http://bugzilla.gnome.org/show_bug.cgi?id=165226
I guess that automatic saving of snapshots (there are also requests for automatic filename increments, see http://bugzilla.gnome.org/show_bug.cgi?id=94364) might be a bit more feasible than storing files into Subversion.
Another, different approach could be to save the entire undo history in the XCF file, see http://bugzilla.gnome.org/show_bug.cgi?id=148930. This should mostly eliminate the need for saving previous versions of images except if you want them in a different format.
HTH, Michael
gimp and subversion
Hi!
That's not true. Subversion fully supports binary diffs. So if you have an uncompressed .bmp image and you changed one pixel, you'll get a very small diff stored. Of course, if your image is compressed or otherwise encoded in a "weird" way, the diff may be much more substantial. Maybe you're confusing Subversion with CVS where each version of a binary file is an entire copy.
Like I said, Subversion has good support for binary diffs. So do other version control systems like Monotone. RCE by the originator of RCS ( http://www.aicas.com/rce.html ) can handle binary diffs, but only operates on a single byte at a time. If you want to handle compressed or encoded data efficiently, you may need to implement domain-specific logic. Rational ClearCase may have such functionality, but I didn't have any experience with it, so I can't tell you.
I think what he meant was a way to view previous images or differences between various images by interfacing with Subversion.
Shlomi Fish
--------------------------------------------------------------------- Shlomi Fish shlomif@iglu.org.il Homepage: http://www.shlomifish.org/
Chuck Norris wrote a complete Perl 6 implementation in a day but then destroyed all evidence with his bare hands, so no one will know his secrets.
gimp and subversion
Øyvind Kolås in his GEGL video/talk suggested that the post-GEGL xcf format might be just a collection of single images tied-together with an XML file and stored in a zip container (like the opendocument format).
Unpacked into a folder, this format would be well suited for storage in a system like subversion - All that would be needed is for the gimp to be able to read/write the folder directly.
gimp and subversion
Shlomi Fish wrote:
Hi!
that was indeed my intent :)
cheers
Bernhard
