is it possible to combine icons
is it possible to combine icons Tonio 08 Feb 00:37
  is it possible to combine icons Jakub Steiner 08 Feb 00:42
Tonio
2007-02-08 00:37:51 UTC (about 18 years ago)
On windows (I imagine same on other OS's) an icon file can contain numerous icon files (e.g. 16x16, 32x32, 48x48) which are used depending on file view (list, details, thumbnails).
After creating the different icons with the gimp, is it possible to combine then into one? :)
If not, can anyone recommend a tool that can do this?
Thank you, Rael
_____________________________________
Jakub Steiner
2007-02-08 00:42:52 UTC (about 18 years ago)
You should be able to do this with the winicon exporter in GIMP. At least in the 2.3 version it allows to save a layered image as a multi-resolution window icon.
cheers
