acting on several layers
acting on several layers T F 26 Jan 05:03
  acting on several layers Joao S. O. Bueno Calligaris 26 Jan 17:23
   acting on several layers Geoffrey 26 Jan 20:45
    acting on several layers Scott Bicknell 26 Jan 21:17
     acting on several layers David Gowers 27 Jan 02:48
T F
2007-01-26 05:03:53 UTC (about 18 years ago)
is there a way (and tutorial) on applying changes to several layers at once? for example .... as if they had already been merged?
tia mike
2007-01-26 17:23:40 UTC (about 18 years ago)
You can't paint on seeral layers at once.
However, you can transform together (i.e. move, scale, rotate) several layers: there is a linking feature in the GIMP.
Linked layers are toggled by clicking just to the right of the eye visibility icon on the layers dialog.
js ->
tia
mike
Geoffrey
2007-01-26 20:45:28 UTC (about 18 years ago)
What if you created a separate transparent layer on top of the layers you want to paint. Paint on this layer then merge it with the layers you want to have it applied?
Scott Bicknell
2007-01-26 21:17:59 UTC (about 18 years ago)
You can do that if you do all the painting on the transparent layer and then duplicate it for each layer you want to merge it with.
David Gowers
2007-01-27 02:48:03 UTC (about 18 years ago)
Copy Visible + Paste onto each destination layer is a better way to do it. Or scripting the propagation of the paint layer -- that would be a simple modification to do to my Apply Layer command
