Idea - Color Scheme Generator
Idea - Color Scheme Generator Eric P 25 Jan 02:50
  Idea - Color Scheme Generator Sven Neumann 25 Jan 07:59
   Idea - Color Scheme Generator Eric P 26 Jan 03:59
    Idea - Color Scheme Generator Sven Neumann 26 Jan 23:49
Eric P
2007-01-25 02:50:22 UTC (about 18 years ago)
Wouldn't it be cool if GIMP implemented something like this DHTML Color Scheme Generator? http://wellstyled.com/tools/colorscheme2/index-en.html
I'm learning GTKMM at the moment. Not sure when I'll get around to C/GTK+. Give me a couple years.
EP
2007-01-25 07:59:22 UTC (about 18 years ago)
Tried Agave yet? http://home.gna.org/colorscheme/
Not sure if this makes sense as a GIMP plug-in. But if GIMP integration is considered important, it would probably be easy to add some code to Agave that allows it to be run as a GIMP plug-in.
Eric P
2007-01-26 03:59:16 UTC (about 18 years ago)
Actually, I just ran across that app a few days ago for the first time. It's GTKMM.
This may sound naive, but is it possible to integrate C++/GTKMM code with GIMP?
EP
2007-01-26 23:49:18 UTC (about 18 years ago)
I don't see how using a C API from C++ code should pose a particular problem.
