Help !!!
Help !!! Alf Strandgard 03 Jan 21:39
  Help !!! Scott Bicknell 03 Jan 23:59
  Help !!! Tim Jedlicka 04 Jan 06:44
Alf Strandgard
2007-01-03 21:39:23 UTC (over 18 years ago)
Help !!!
Hello:
I am a novice with GIMP. At work I am doing a variety of small office tasks, including creating pictures and creating labels on the screen.
When I create text and place it on the screen (transparency).....no problem. Once I come back to the same screen and want to move the text.........or edit the text..........I have trouble. I can't easily locate (click on) the original text I entered. I think it has to do with layers.
I have read the users manual.....no help.
Does anyone have an easy fix or advice on layers and text for me???
Thanks.
Alf in Florida
Scott Bicknell
2007-01-03 23:59:22 UTC (over 18 years ago)
Help !!!
On Wednesday 03 January 2007 12:39 pm, Alf Strandgard wrote:
Hello:
When you want to move a text layer you either must place the cursor directly over the text, or select the Move the current layer radio button in the move tool's options dialog.
Tim Jedlicka
2007-01-04 06:44:58 UTC (over 18 years ago)
Help !!!
On 1/3/07, Alf Strandgard wrote:
* want to move the text………*
In the Layer dialogue (it should be on the screen, but you can also get to it via Ctrl-L or Dialogs->Layers), make sure your text layer is active/highlighted. It should have a big "T" as an icon and have some of your text. Then click on the "Move tool" - looks like a plus sign with arrows on each end (or "m"), then in that tool's dialog select the "Move the Current Layer" radio button - this will make it easier to move the text layer.
*or edit the text…… *
Double click on the "T" in the layers dialog. A separate box with all your text should appear. This is where you can edit the text.
Hope that helps.
