Scripting questions...
Scripting questions... Jerry Baker 26 Nov 16:35
  Scripting questions... David Gowers 26 Nov 23:52
Scripting questions... Saul Goode 27 Nov 02:12
Jerry Baker
2006-11-26 16:35:55 UTC (over 18 years ago)
Using python, I'm trying to find the color that is used on a layer. The layer has an alpha channel and it only uses 1 color on the layer. The problem is, I don't know where the colored pixels are. It may only be one pixel anywhere on the layer, or the entire layer may be filled.
I also need to find the color used on a text layer...
Anyone have any ideas ?
Thanks a million...
jbaker
David Gowers
2006-11-26 23:52:06 UTC (over 18 years ago)
The only way I know is the slow way:
* initialize a pixel_rgn * iterate across rows and down columns * look at each pixel. if its alpha is non-zero (ie. ord(pixval[3]) > 0)) then store the color and exit the loop.
This (and the other text data) is stored in a parasite attached to the text layer. The parasite data is textual, and easy to understand.
Saul Goode
2006-11-27 02:12:05 UTC (over 18 years ago)
A destructive way (i.e., work on a duplicate) of doing this would be to scale your layer down to 1x1 pixels and then fetch the color of that pixel (using the PDB function 'gimp-drawable-get-pixel')
Thanks a million...
jbaker
