From script-fu to tiny-fu, first problems...
From script-fu to tiny-fu, first problems... Ismael Valladolid Torres 20 Nov 15:28
  From script-fu to tiny-fu, first problems... Sven Neumann 20 Nov 16:13
   From script-fu to tiny-fu, first problems... Ismael Valladolid Torres 20 Nov 17:04
  From script-fu to tiny-fu, first problems... Simon Budig 20 Nov 17:00
   From script-fu to tiny-fu, first problems... Ismael Valladolid Torres 20 Nov 18:19
2006-11-20 15:28:48 UTC (over 18 years ago)
Concerned by the fact that my developed script-fu which used to do the thing nicely in previous GIMP versions, no longer works with 2.3, and also by the fact that it seems like script-fu is no longer being supported in favour of tiny-fu, I am trying to turn my script-fu into a shiny tiny-fu.
To serve as a guideline, I am seeing default scripts. As an example, it seems like addborder.sct and addborder.scm are the same script, where simply all ocurrences of script-fu have been replaced into tiny-fu. I've done the same with my script but when launched it complains:
Error while executing (load "C:\\cygwin\\home\\ivt351\\.gimp-2.3\\scripts\\analogize.sct")
Error: eval: unbound variable:
I am using GIMP 2.3.11 on Windows 2000. Find attached the non-working tiny-fu analogize.sct.
Any ideas, comments and suggestions are welcome.
Cordially, Ismael
2006-11-20 16:13:00 UTC (over 18 years ago)
We have merged the Tiny-Scheme interpreter into Script-Fu in the meantime. That means that Tiny-Fu doesn't exist any longer. Scripts with the .sct extension are not going to be recognized by GIMP 2.4.
Simon Budig
2006-11-20 17:00:26 UTC (over 18 years ago)
Actually the naming is not that important: In current CVS all the scripts have the script-fu prefix again although the interpreter has been changed to tinyscheme, no need to change the names.
There is one significant difference though:
(define (tiny-fu-analogize img
drawable
contrast
saturation
bright-opacity
shadow-opacity
duplicate-shadow
flatten
copy)
(set! image (if (= copy TRUE) (car (gimp-image-duplicate img)) img))
(gimp-image-undo-group-start image)
(set! layer (car (gimp-image-flatten image))) (set! image-width (car (gimp-image-width image))) (set! image-height (car (gimp-image-height image)))
Here you define ("assigning a value") a variables before declaring ("making the variable known to the interpreter") them. This used to work with the SIOD-interpreter of the old script-fu but is considered very broken, because it pollutes the namespace. With the tinyscheme interpreter all variables have to be declared before they can be (re)defined. I suggest that you look at other scripts how they use the let*-construct to simultaneously declare and define variables.
In your case you probably have to assign a lot of dummy-values to the declared variables, since you invoke the undo-group-start on the image very soon. But if the variables are declared in the let*-block you can later use set! to assign new values to them.
(cond ((= duplicate-shadow TRUE)
(set! shadow-layer2 (car (gimp-layer-copy shadow-layer 0))) (gimp-image-add-layer image shadow-layer2 0)))
you can also use (if (condition) (if-part) (then-part)) here, that would make your script a bit more easy to read.
I hope this helps, Simon
2006-11-20 17:04:00 UTC (over 18 years ago)
Sven Neumann escribe:
Thanks for the info, anyway any idea why my script could be failing?
Cordially, Ismael
2006-11-20 18:19:47 UTC (over 18 years ago)
Simon Budig escribe:
Amazingly, this was and end-of-line problem: The script was downloading with UNIX end-of-line and it wasn't working on GIMP for Windows as it expects DOS end-of-line.
I also had to declare variables using let* and changing gimp-palette-set-foreground into gimp-context-set-foreground. Now the script works and, eh, much faster than previously using script-fu!
I hope this helps,
It helped, thanks a lot for the feedback.
Cordially, Ismael
