python problem with gimp-2.3.12 / win32
python problem with gimp-2.3.12 / win32 lode leroy 09 Nov 08:51
  python problem with gimp-2.3.12 / win32 Sven Neumann 09 Nov 09:01
lode leroy
2006-11-09 08:51:53 UTC (over 18 years ago)
I'm having problems with the python support in gimp-2.3.12...
When I run the script "Xtns->Python-Fu->Test->Sphere", it works perfectly when I close the generated window in between tests.
When I leave the new window open, the python plugin locks up after clicking the "OK" button.
Is this a know problem, or am I doing something wrong?
I used to use gimp-2.3.9+ActivePython+gtk+-2.8.6 which worked fine.... Currently I have the following packages installed:
gtk+-2.10.6-setup.zip python-2.4.4.msi
pycairo-1.2.2-2.win32-py2.4.exe
pygtk-2.10.3-1.win32-py2.4.exe
gimp-2.3.12-i586-setup.zip
any thoughts?
Thanks. -- lode
__________________
2006-11-09 09:01:33 UTC (over 18 years ago)
Consider 2.3.12 to be broken for the Windows platform. The next development snapshot should fix this issue.
