Animation
Animation | ajspires@gto.net | 09 Oct 04:05 |
Animation | Rikard Johnels | 09 Oct 12:13 |
Animation | Dennis | 09 Oct 12:29 |
Animation | Chris Mohler | 10 Oct 02:57 |
Animation | vt | 09 Oct 12:43 |
Animation | Jozef Legeny | 09 Oct 20:05 |
Animation | Joao S. O. Bueno Calligaris | 10 Oct 05:20 |
Animation
I have a simple animation I want to do for a website which involves fading a photo gradually (I assume by increasing opacity of a layer or decreasing opacity of layer containing photo) and replacing it with text (by increasing opacity of layer containing text?) And then this text will be a link to a web page. I have no idea how to do this. I am a total amateur looking to learn this slick little trick.I am new to Gimp but learning. Can you help me please? Andrea
-------------------------------------------------------------------- This mail sent through WebMail | Courtesy of Execulink
Animation
Unless the link only shall be present as the text appears, i would simply
construct a looping animated gif and use it with tag...
There are several tutorials on how to make a animated gif via Gimp, so that
part shouldn't be a big problem.
I have made a banner once, (loooong time ago) for a now closed web page.
And thats how i did it. A plain moving gif and a tag for the link.
Animation
I have never tried it but you might want to take a different approach:
- use css to hide your image
- use css to show a text link
The dojo toolkit might be able to accomplish this. Go to the website http://dojotoolkit.org/ click in the menu on "See in action" and then on the catagorie "effects".
Dennis.
little trick.I am new to Gimp but learning. Can you help me please? Andrea-------------------------------------------------------------------- This mail sent through WebMail | Courtesy of Execulink
Animation
Monday 09 October 2006 05:05, ajspires@gto.net raš?:
Generally it is not a good idea to convert photo to gif format as it has many limitations. But in this case you have to save in this format as it is default format for animations on web. What is the size of photo (in pixels and in kilobytes (kb))? To accomplish your task we'll be using multiple layers and size in kb of final work will be much bigger. Hence the question: will it be on internet or only in LAN?
Animation
however there is a problem with GIF images, because even if they suport transparency they don't have an alpha channel (opacity) they only have one 100% transparent color. You can still do the fading effect; however you'll have to work with fixex background color. (I mean if the background of your site is for example white, you make it fade to white in GIMP)
Other idea might be using opacity propriety of CSS3 (you decrease the opacity in a loop from 100 and when you reach 0 you'll delete the image and place the text), but not many browsers support this at the time being. Either way, it has little to do with GIMP if you do it this way.
Animation
On 10/9/06, Dennis wrote:
I have never tried it but you might want to take a different approach: - use css to hide your image
- use css to show a text linkThe dojo toolkit might be able to accomplish this. Go to the website http://dojotoolkit.org/ click in the menu on "See in action" and then on the catagorie "effects".
Dennis.
I've tried to fade a photo before (it never worked out that well) - on a whim I followed your link, and......WOW! I've only tested it in FF on *nix, but it looks fantastic! Not really GIMP-related, but cool anyway.
Chris
Animation
I do not like what I will write you, for I am normally comitted to
freesoftware options only.
But for this case, the easiest way to achieve what you desire is to
use Flash. No, the Gimp cannot create it. There are Free programs
that can, I do not know then. I guess event he free Gnu Flash Player
- GNASH - could handle a file that would do just that, although it
is not packed with all features in flash 9. - however, most people on
the web would see your final result in a proprietary plug-in - that
is why I dislike it.
CSS3, as others have suggested simply is not widespread, and few
people would be able to see it.
That said, if youcan do that with GIMP alone: You can implement most of this as an animated gif, as people had written. You just can't create the link in the end - you'd have to use Javascript to do that - or - just let the whole image be a link all the time, and just press the text inside it at the end.A small adaptation that would simplify your work and allow you to make this with an animated gif.
Create an image, with your photo, the size you wnat it to be on the web. Create a new layer, with the background color you wish for the text, add yoru text, and, witht he text layer selected, combine it with the background layer bellow. Now, duplicate the layer with your photo, and use the plug-in "Filters->Animation->Blend" - it will create another iamge with all the intermediate layers you need.
Save this one as "gif" and pick "animation" on the dialog that appears. Select your parameters, and there you go. Tip: if you wnat a certain frame to last longer than the others (let's suppose you want your aniamtion to loop, but you want the the text to be visible for 5 seconds before repeating), you put the duration of the frame in the frame title, inside parentheses - a name such as "final (5000ms) " (the time is in milisconds)
JS
Then, with
------------------------------------------------------------------- - This mail sent through WebMail | Courtesy of Execulink
