problems scripting plugin-in-dog
problems scripting plugin-in-dog John Storey-Bishoff 02 Aug 18:14
  problems scripting plugin-in-dog Sven Neumann 08 Aug 12:28
John Storey-Bishoff
2006-08-02 18:14:51 UTC (over 19 years ago)
I was trying to apply the DoG edge detection plug-in in a script and have been seeing the following errors.
(gimp:5944): Gimp-Core-CRITICAL **: gimp_drawable_mask_bounds: assertion `gimp_item_is_attached (item)' failed
(gimp:5944): Gimp-Core-CRITICAL **: gimp_drawable_shadow: assertion `gimp_item_is_attached (item)' failed
(gimp:5944): Gimp-Base-CRITICAL **: tile_manager_get: assertion `tm != NULL' failed
If you have had success using this plug-in in a script could you let me know.
I am essentially: - loading my image
- creating a new layer
- running the plugin passing in my image and drawable layer.
Here are the commands I'm using.
(file-dicom-load 0 "/home/storeybish/a/scans/mri_july25/links/13526192" "/home/storeybish/a/scans/mri_july25/links/13526192") (gimp-layer-new 1 480 768 2 "layer" 100 0) (plug-in-dog 1 1 3 4.0 12.0 1 1)
This also leaves the undo stack in a bad state.
If I display the image before applying the plug-in-dog I can run the edge detection manually.
Any help appreciated. Thanks,
John
___________________________________________________________ All new Yahoo! Mail "The new Interface is stunning in its simplicity and ease of use." - PC Magazine http://uk.docs.yahoo.com/nowyoucan.html
2006-08-08 12:28:48 UTC (about 19 years ago)
On Wed, 2006-08-02 at 17:14 +0100, John Storey-Bishoff wrote:
(file-dicom-load 0
You need to add the layer to the image before you can manipulate it.
