Some photograph morphing tricks
7 of 7 messages available
Some photograph morphing tricks Tanveer Singh 31 Jul 19:02
  Some photograph morphing tricks Mukund 31 Jul 19:09
   Some photograph morphing tricks Dave Neary 31 Jul 19:22
    Some photograph morphing tricks Tanveer Singh 31 Jul 22:20
     Some photograph morphing tricks David Neary 31 Jul 23:34
      Some photograph morphing tricks Jeffrey Brent McBeth 01 Aug 00:08
       Some photograph morphing tricks Tanveer Singh 01 Aug 17:34
Tanveer Singh
2006-07-31 19:02:12 UTC (over 18 years ago)
I have some snaps of me and my wife which are color. I have seen some lovely pics in which the faces and skin is BW, cloths are color and background is BW. How to do such stuff in gimp? Tanveer
Mukund
2006-07-31 19:09:49 UTC (over 18 years ago)
Go through the GIMP tutorials:
http://www.gimp.org/tutorials/
Dave Neary
2006-07-31 19:22:38 UTC (over 18 years ago)
Also, gimpguru: http://www.gimpguru.org/ (there's a big tutorials section).
And in particular, this tutorial: http://www.gimpguru.org/Tutorials/SelectiveColorization/
Cheers, Dave.
PS. I don't know if Eric is on this list - if you are, shout! You're one of my heros.
Tanveer Singh
2006-07-31 22:20:37 UTC (over 18 years ago)
Great tutorial. But one hitch.In my case I want to make B&W a small area. So I am guessing I need to interchange the layers. I.e color over BW. But when I make the original image Greyscale, any layer I create above it is also greyscale. How to make a layer greyscale, any ideas?
David Neary
2006-07-31 23:34:10 UTC (over 18 years ago)
Not necessarily. But you certainly can.
There's another gimpguru tutorial (linked from that one) on that issue. It's also on gimp.org - I don't know the URL off the top of my head, but if you have a quick hunt around you should find it easily.
Cheers, Dave.
2006-08-01 00:08:20 UTC (over 18 years ago)
I would do this nice and simple. Make sure that you have the areas you want to be greyscale selected (either select them or select the color bits and invert the selection), then go to Colors->Desaturate
Jeff
Tanveer Singh
2006-08-01 17:34:30 UTC (over 18 years ago)
Jeff
I did it!
http://tanveer.smugmug.com/gallery/1718165/1/85342367/Large Thanks for the help guys. I went with the Layers technique Tanveer
