Probably simple, need to know right approach
7 of 7 messages available
Probably simple, need to know right approach Simon Roberts 31 Jul 18:01
  Probably simple, need to know right approach VytautasP 31 Jul 18:35
   Probably simple, need to know right approach Simon Roberts 31 Jul 18:48
    Probably simple, need to know right approach saulgoode@brickfilms.com 01 Aug 23:30
  Probably simple, need to know right approach Matthias Julius 31 Jul 18:46
   Probably simple, need to know right approach--SOLVED Simon Roberts 31 Jul 18:52
  Probably simple, need to know right approach Roel Schroeven 31 Jul 21:53
Simon Roberts
2006-07-31 18:01:21 UTC (almost 19 years ago)
Hi all,
I'm trying to put a bunch of photographs together as a collage. As I do so, I want to be able to resize and reposition each one repeatedly until I'm happy with the overall layout. So far what I'm doing is pasting each image into a new layer, however, this isn't very satisfactory because the layers are all the full size of the image, so when I resize them, I can't really see what the effect will be on the image itself. Similarly, repositioning the layer is a rather hit and miss way of repositioning the image that it contains.
What should I be doing?
TIA Simon
"You can tell whether a man is clever by his answers. You can tell whether a man is wise by his questions." ? Naguib Mahfouz
___
VytautasP
2006-07-31 18:35:55 UTC (almost 19 years ago)
Simon Roberts wrote:
Hi all,
TIA Simon
Image>Canvas size
Make it the size you like (or can).
Do not be afraid to make it bigger - you'll have more freedom to move pics. After you're satisfied with the result Image>Fit canvas to layers.
Matthias Julius
2006-07-31 18:46:10 UTC (almost 19 years ago)
Simon Roberts writes:
In the Layer menu is an item "Autocrop Layer" (at least in The Gimp 2.2) that will resize the layer to the size of the pasted image.
On the other hand when I paste an image and then right click the Floating Selection in the Layers dialog and click New Layer the new layer has just the size of the pasted image.
Matthias
Simon Roberts
2006-07-31 18:48:35 UTC (almost 19 years ago)
Hi all,
I do
so
the
and
TIA Simon
Image>Canvas size
Thanks for this, but I fear I wasn't clear (or maybe I'm just misunderstanding your reply). My canvas is big enough to allow me to move the layers around (it's 20x30 inches @300 dpi, something of a memory hog :)
The problem is that when I move or resize the individual layers that contain the individual images, I don't get a realistic preview of where the image will be because the image is only a small fraction of the layer size.
If I knew how to paste an image into a new layer, and have that layer become the size of the pasted image, that would be a help, but I'm wondering if I'm just plain approaching this all wrong.
How should I use GIMP so that each image I paste in can be manipulated independently (resized, repositioned)--as if each were a separate "object" rather than being pixels in the same pool?
Thanks again, Simon
___
Simon Roberts
2006-07-31 18:52:49 UTC (almost 19 years ago)
I do
so
the
and
GACH! How did I miss that!
Many thanks, this is exactly what I needed.
Cheers, Simon
___
Roel Schroeven
2006-07-31 21:53:48 UTC (almost 19 years ago)
Simon Roberts schreef:
Hi all,
I often use Inkscape for that kind of work; it's vector based so it handles each imported bitmap as an object that can be resized and repositioned at will.
2006-08-01 23:30:21 UTC (almost 19 years ago)
Quoting Simon Roberts :
It sounds as though you are creating a New Layer *then* pasting your photograph into it. If so, this is counter-productive. If the photographs are files on your harddrive, just create a New Image from the Toolbox File menu and from the Image's File menu do an "Open As Layer" to open the rest of the photographs 'all-at-once' (hold down the CTRL key as you click on each of the files in the Open Dialog). The photographs will be added to the image, each on a separate layer. You will most likely wish to perform an "Image->Fit canvas to layers" afterwards so that no layers extend beyond the image boundaries.
If I understand you correctly what you desire to do is not much different from what I did when I created the following iTunes spoof.
http://www.postbrickfilms.com/saulgoode/Images/ForumPosts/iGallery.jpg
Each of the images was on a separate layer (as well as the text; I had over 80 layers) and had to be resized and cropped to fitted the page in the proper location. The GIMP made this process very easy (it only took me about an hour). Since most of the images came from the Internet, I just used drag-n-drop to put them on new layers in the image.
