Problems building with printing and missing GimpFu in stable cvs?
Problems building with printing and missing GimpFu in stable cvs? Rikard Johnels 28 Jul 19:47
  Problems building with printing and missing GimpFu in stable cvs? Carol Spears 28 Jul 20:01
  Problems building with printing and missing GimpFu in stable cvs? VytautasP 28 Jul 22:12
   Problems building with printing and missing GimpFu in stable cvs? Rikard Johnels 28 Jul 22:24
Rikard Johnels
2006-07-28 19:47:58 UTC (over 18 years ago)
hello all
I have tried to compile gimp 2.2 via cvs. I followed the page http://www.gimp.org/source/howtos/stable-cvs-get.html and then went on to http://www.gimp.org/source/howtos/stable-cvs-build.html
Then i went to http://gimp-print.sourceforge.net/ and downloaded the sources for the latest gutenprint 5.0 and got it compiled and installed without problems.
Re-did the config for gimp. Still no go. It still complains about missing printing. So i stuck with --disable-print to get going.
gimp compiles fine, and installs nicely. But as i try to run the centerguide.py script i get a error stating module gimpfu is missing.
Where can i find the ginpfu stuff? I tried googling but to no avail. I dont understand how to get and install it. Let alone find WHAT to get...
Also, why doesn't the cvs find and use gutenprint-5.0? The page http://www.gimp.org/source/#gimp_from_cvs clearly states "gimp-print >= 4.2.6" and the gimp-print pages states "Gutenprint was formerly called Gimp-Print" Aren't they compatible? Do i have to downgrade to Gimp-Print 4.2.7
*confused*
Carol Spears
2006-07-28 20:01:43 UTC (over 18 years ago)
pygimp is in the gimp source.
./autogen.sh --help should tell you how to enable it to be built (if it has been disabled)
i am pretty sure that configure leaves a log what it saw and did -- i can't remember the name of that file so when i need to look at what is happening: ./autogen.sh>configure.spew
then i read configure.spew and it is usually pretty clear in there what is missing and why.
VytautasP
2006-07-28 22:12:03 UTC (over 18 years ago)
hello all
*confused*
Maybye you should do
#ldconfig
after compiling and installing.
If you looked for ginpfu you couldn't find it, cause it spells gimpfu.
Rikard Johnels
2006-07-28 22:24:13 UTC (over 18 years ago)
#ldconfig
Typo from my part. I know it is gimpfu. And the ldconfig doesn't change anything :( I remade it several times, ldconfig'ed it and still no go Its even rebooted in between the different trials
