how to copy mask to layers
how to copy mask to layers Thadeu Penna 16 Jul 20:26
  how to copy mask to layers saulgoode@brickfilms.com 17 Jul 20:56
Thadeu Penna
2006-07-16 20:26:53 UTC (almost 19 years ago)
I have a mask in one layer that I would like to copy to all others. Is it possible in Gimp, besides going one-to-one ?
2006-07-17 20:56:17 UTC (almost 19 years ago)
Quoting Thadeu Penna :
This would be very easy to script. In fact, I whipped up a Script-fu that might meet you needs and it is available at
http://flashingtwelve.brickfilms.com/GIMP/Scripts/copy-mask.scm
What the script does is copy the layer mask of the active layer to all visible layers (unless they already have a layer mask or they do not have an alpha channel). If the active layer does not have a layer mask then the script will use a grayscale copy of the layer (if the active layer is visible then it also will have a mask added). There is very little error checking and the script will fail if any of the visible layers are not the same size as the active layer.
