script-fu question
script-fu question Sven Görsmann 12 Jul 11:53
  script-fu question saulgoode@brickfilms.com 12 Jul 15:18
   script-fu question Sven Görsmann 13 Jul 11:36
Sven Görsmann
2006-07-12 11:53:43 UTC (over 19 years ago)
script-fu question
Hi there!
I have the following problem: in the past i used some gimp script-fus that i wrote to run under gimp 1.1.x and 1.2.x. Then script-fu function names/calls changed a lil bit and the scripts didn't work anymore. The script-execution ends in a pop-up-box with errors. Same thing with other cool scripts i collected in the past for the older versions of gimp.
Now i want to convert the scripts to work und the actual gimp version(s) again.
My question: Do you know any "manuals" or links that could help me in converting the old scripts to work again, for example a list which shows the old function on the left an the new on the right.....or something like a how-to ?
Sven Goersmann
2006-07-12 15:18:38 UTC (over 19 years ago)
script-fu question
Kevin Cozens provides a script written in Perl which will convert older script-fus to work with the newer API (http://www.interlog.com/~kcozens/software/gimp/2.0/script-update.pl).
Even if you do not have Perl on your machine, you should be able to use the information in the script to determine the necessary modifications.
Quoting Sven Görsmann :
Sven Görsmann
2006-07-13 11:36:26 UTC (over 19 years ago)
script-fu question
Thanks for the pointer!
I tried it on one of the scripts and it worked perfect....hope the other scripts con be converted so easy, too.
