Stroke Paths - Taper option?
3 of 4 messages available
Stroke Paths - Taper option? Ben Schreiner 27 Jun 16:37
  Stroke Paths - Taper option? Olivier Ripoll 27 Jun 17:29
  Stroke Paths - Taper option? Joao S. O. Bueno Calligaris 28 Jun 04:58
  200606272359.53255.gwidion@... Joao S. O. Bueno Calligaris 28 Jun 04:59
Ben Schreiner
2006-06-27 16:37:24 UTC (almost 19 years ago)
I'd like to be able to taper the size of the brush (up or down) as it strokes along a path with a stroke line or possibly even a paint tool.
I assume this would at least need a script to achieve.
Is there any way for this to be done easily, or should I be looking at commissioning a script and/or development on the path tool.
I much prefer working with vectors than with rasters in general, but Inkscape doesn't seem to support this either.
TIA
Ben Schreiner
Olivier Ripoll
2006-06-27 17:29:58 UTC (almost 19 years ago)
TIA
Ben Schreiner
The only idea I can come with is to use a animated brush (image pipe) having lots of brushes from 1 pixel to the maximum size you want. Then, stroking using the paintbrush tool would be close to what you want.
The parametric brushes could be a nice tool for that too, if I could find any documentation on how to generate them ;)
Best regards,
Olivier
2006-06-28 04:58:32 UTC (almost 19 years ago)
Hi ben,
I have a python script that follows paths and paint strokes perpendicular to them.
It does not vary the stroke length - just the color, but it would be a trivial change.
The final result is far from perfect, as it is a simple script I created for an effect I wanted once. So ther emay be lots of empty spaces unless you reduce spacing a lot.
I will send you the script privately - I hoipe you are on linux and have gimp-python installed.
JS ->
TIA
Ben Schreiner
