How to use gimp-layer-set-opacity in batch mode?
How to use gimp-layer-set-opacity in batch mode? Klaus Schmidinger 22 Jun 10:42
  How to use gimp-layer-set-opacity in batch mode? saulgoode@brickfilms.com 22 Jun 12:00
   How to use gimp-layer-set-opacity in batch mode? Klaus Schmidinger 22 Jun 13:03
Klaus Schmidinger
2006-06-22 10:42:40 UTC (over 19 years ago)
Assume there is an image file named "test.png" that contains some drawing with an alpha channel. The alpha channel is used to create an empty (fully transparent) background, while the foreground drawing is completely opaque.
What I want to do is to make the foreground drawing 50% transparent. In order to do so, I use the following script:
---------------------- cut -------------------------------------- #!/bin/sh
gimp -i -b - <
So what exactly am I doing wrong here?
Any help would be greatly appreciated.
Klaus Schmidinger
2006-06-22 12:00:11 UTC (over 19 years ago)
Quoting Klaus Schmidinger :
"GIMP: Not enough visible layers for a merge. There must be at least two."
The CVS version of the GIMP permits "merging" a single layer. If you are unable to get the CVS version, you can try the following approach which applies a 50% (GRAY) mask to the layer.
------- (let* (
(image (car (gimp-file-load 1 "test.png" "test.png"))) (drawable (car (gimp-image-get-active-layer image))) (mask (car (gimp-layer-create-mask drawable ADD-WHITE-MASK)))) (gimp-layer-add-mask drawable mask) (gimp-brightness-contrast mask -127 0) (gimp-image-remove-layer-mask image drawable MASK-APPLY)
(gimp-file-save RUN-NONINTERACTIVE image drawable "test-50.png" "test-50.png")
(gimp-quit 0)
Klaus Schmidinger
2006-06-22 13:03:01 UTC (over 19 years ago)
Thanks a lot - works like a charm!
Klaus Schmidinger
